Old 02-20-2006, 06:38 PM   #11
Member Number: 837
Re: will 285/70-17 tires fit?
would 33's fit with a 2" body lift? I think it'd be a tight fit but you never know
K_os is offline
Old 02-20-2006, 07:33 PM   #12
Member Number: 519
The article in 4WD Toyota Owner Magazine from the FJ Cruiser test drive through the Rubicon Trail stated that the only modifications they did to that truck was 33 inch BFGoodrich tires and released a bit of air pressure to them.
tacomaDave is offline
Old 02-20-2006, 08:53 PM   #13
Official Field Agent
Topless4runner's Avatar
Member Number: 83
Send a message via AIM to Topless4runner Send a message via Yahoo to Topless4runner
the factory tires stand about 32" tall, so i seriously doubt there would be need of any kind of lift, at most maybe 1".
"Liberty is never unalienable; it must be redeemed regularly with the blood of patriots or it always vanishes. Of all the so called human rights ... liberty is least likely to be cheap and is never free of cost." - Robert A. Heinlein
Topless4runner is offline
Old 02-20-2006, 09:05 PM   #14
VeilsideGS4's Avatar
Member Number: 879
grit previously said:
What needs to be done to run 285 series tires,will they fit without a lift?It would be easier for warranty reasons if a lift wasn't needed.
The FJ is based on a Land Cruiser Prado which is a GX 470 which is also a 4Runner. I know for a fact you can put 22's on these vehicles and lower them. I think you can do it without a lift kit.
VeilsideGS4 is offline
Old 02-20-2006, 09:11 PM   #15
Member Number: 837
****in sweet.. I still might do a 2" inch body lift.. just for the hell of it. looks basically
K_os is offline
Old 02-21-2006, 07:50 AM   #16
wakesurfboy's Avatar
Member Number: 574
I recheck and its 265/70 R17 = 31.7". It was good news before I mess up!
[i]Darth Cruser, Warn Rear & front bumper + 9.5ti, MTZ 33 x 12.5 /17 and the fantastic King shocks kit!
wakesurfboy is offline
Old 02-21-2006, 04:30 PM   #17
Good Times's Avatar
Member Number: 406
Rubbing and not rubbing will vary according to wheel and tire combination. I would suspect that for the FJ you'll want to lift it anyway because I'm pretty certain it'll rub at full lock or even at full compression. Some food for thought.
Regardless, you'll want to lift it anyway since you'll want that additional clearance.
Good luck
Good Times is offline
Old 02-23-2006, 11:59 PM   #18
Dirt Hound's Avatar
Member Number: 1001
I'm hoping to use the 265/75R16 Goodyear MT/R's from my 4Runner on the FJC. Does anyone know if the 6 bolt pattern and the 16" wheel will be compatible with the FJC?
Dirt Hound is offline
Old 02-24-2006, 12:12 AM   #19
CatDaddy's Avatar
Member Number: 820
Bolt pattern's the same. The 16" TRD rims are an option for the FJ. So, as long as the backspacing & offset's close to stock then you ought to be okay.
"...manly man manual mandingo..." - Pancho
Had to pass on the FJ.
Bought a silver Double Cab Taco w/ MT, OC, TO, & DZ instead.
CatDaddy is offline
Old 03-18-2006, 12:59 PM   #20
Member Number: 671
Is anyone going to try a 285x70-17 on there FJ this week to see if it fits?
thanks
grit is offline
