Old 03-25-2006, 04:46 PM   #61
granger's Avatar
Member Number: 50
Re: will 285/70-17 tires fit?
GTA_XAN previously said:
Thanks. You would be fine with the Wrangler MT/R (275/70/17). Great tire, especially if you are not winter driving.
Thanks! Any idea how they do on wet roads? I have been planning on going with 265/70R17 Nitto Terra Grapplers
TLCA#15587
granger is offline
Old 03-25-2006, 04:47 PM   #62
AlbuqChiro's Avatar
Member Number: 1160
So, I cant put a lift on her because of garage clearance..so, need some advice...BFG A/T 265/70-17, or a Goodyear Wrangler A/T 275/70-17???? Going to be using as both my comuter car and for a lot of off road camping in New Mexico.
AlbuqChiro is offline
Old 03-25-2006, 04:52 PM   #63
Member Number: 1311
BFG's.
GTA_XAN is offline
Old 03-25-2006, 04:55 PM   #64
ickmann's Avatar
Member Number: 1282
FWIW - If there was a 275/70 17 AT I would jump immediately. I bet the Wrangler MT/R would be perfect... but I highway drive to the cottage every weekend and my family would not be thrilled with the noise.
I had the 285 M/TR 's on my Rubicon and, to tell the truth, the road noise was not that bad...even with the rag top. I was chewing over the thought of putting them on the FJ...just not the 285's....until I lift her.
ick.
ickmann is offline
Old 03-25-2006, 04:59 PM   #65
Member Number: 1311
Tough call. The MT/R's are very good in the wet for what they are... not siped so you will give up some wet traction. You should nose around a TJ forum and get some feedback from the rubicon drivers.
The terra grapplers are used by a few Toureg owners and they love them.
Alternatively look at the Bridgestone A/T Revo's 265/70. Fantastic tire on road, in the wet and commendable off road.
lots of options if you stick to the 265/70.
GTA_XAN is offline
Old 03-25-2006, 05:02 PM   #66
Member Number: 1311
ick.
I found they got noisey after the first 1/3rd wore out. Also they began to slip a little on wet roads. Not dangerously, more of an inconvenience... fast starts were slippery.
GTA_XAN is offline
Old 03-25-2006, 05:08 PM   #67
oldawg's Avatar
Member Number: 1036
Bfg's better all around tire
Just smile and wave boys...just smile and wave....
~TLCA #15196~
oldawg is offline
Old 03-25-2006, 09:51 PM   #68
Member Number: 269
Thats a little tight fit for my comfort.. 1" spacer would probably fix it though
chtucker is offline
Old 03-26-2006, 02:26 PM   #69
Member Number: 1311
oldawg previously said:
Does the rear window work ok with the new tire ? I have a good fix Idea for the rubbing........................Donahue coilover shocks.............Looks nice ! Like the size differance ,A little bigger but not enough to mess with the gearing...Hows the ride with the AT's compared to the stock tires ?
oldawg - the rear window opens ... no need for a spacer. Also, I did get a small rub (as expected) when the wheels were full lock going over a moderate bump abrading the plastic on the 3 inch flange covering the body mount. Since I really do not want to give up the 285's and go back to 265's, I will be looking for something to raise the front 1 inch. The tires ride great, there is a little slop in the steering wheel but that should be expected when the tires are 25lbs heavier and 1.5 inches wider than stock.
GTA_XAN is offline
Old 03-26-2006, 02:33 PM   #70
oldawg's Avatar
Member Number: 1036
oldawg - the rear window opens ... no need for a spacer. Also, I did get a small rub (as expected) when the wheels were full lock going over a moderate bump abrading the plastic on the 3 inch flange covering the control arm. Since I really do not want to give up the 285's and go back to 265's, I will be looking for something to raise the front 1 inch. The tires ride great, there is a little slop in the steering wheel but that should be expected when the tires are 25lbs heavier and 1.5 inches wider than stock.
I agree never look back right...Look into the Donahue coil over shocks thay are adjustable up to 3" , I'm a little iffy on the Revtek kit as it is mostly spacers witch will put allot of strain on your system. Check in with one of the Taco or 4 runner forums see what everyone there is running...
~TLCA #15196~
oldawg is offline
