Old 02-18-2006, 03:19 PM   #1
Member Number: 671
will 285/70-17 tires fit?
What needs to be done to run 285 series tires,will they fit without a lift?It would be easier for warranty reasons if a lift wasn't needed.
grit is offline
Old 02-18-2006, 03:40 PM   #2
wakesurfboy's Avatar
Member Number: 574
Re: will 285/70-17 tires fit?
I have also the intention to put 33" tire as soon I have a confirmation for a fit without any modification to the FJ.
[i]Darth Cruser, Warn Rear & front bumper + 9.5ti, MTZ 33 x 12.5 /17 and the fantastic King shocks kit!
wakesurfboy is offline
Old 02-18-2006, 03:47 PM   #3
CatDaddy's Avatar
Member Number: 820
Doing the basic math, you're looking at 31.6 (265/70-17) vs 32.7 (285/70-17). That's strictly based on stated size - real world diameter isn't usually the same. An extra ~1/2" of height (from hub to tread), plus a little more section width... might fit, might rub... IMO, you'll have to try it out in the tire shop & see.
"...manly man manual mandingo..." - Pancho
Had to pass on the FJ.
Bought a silver Double Cab Taco w/ MT, OC, TO, & DZ instead.
CatDaddy is offline
Old 02-18-2006, 04:43 PM   #4
FJ #8's Avatar
Member Number: 121
33's wont fit wothout a lift will it?
FJ #8 is online now
Old 02-18-2006, 06:00 PM   #5
oceansports's Avatar
Member Number: 313
Didn't the SEMA green display model have 285/70x16 BFGs?
oceansports is offline
Old 02-18-2006, 07:19 PM   #6
Official Field Agent
Topless4runner's Avatar
Member Number: 83
Send a message via AIM to Topless4runner Send a message via Yahoo to Topless4runner
the SEMA FJC (the blue one) had a donahoe (sp?) racing lift on it, essentially longer coilover shocks front and spacers or longer springs in the rear. I think it was 2" of lift.
"Liberty is never unalienable; it must be redeemed regularly with the blood of patriots or it always vanishes. Of all the so called human rights ... liberty is least likely to be cheap and is never free of cost." - Robert A. Heinlein
Topless4runner is offline
Old 02-18-2006, 07:24 PM   #7
Percy's Avatar
Member Number: 65
It only had donahoe coil overs on the front. The rear was a mix of two, OME and something else to give it about 2-3" of lift. But, I would think the lift is pretty much unecessary if you're only raising the size of the tire by about an inch" total. You will want the lift eventually to prevent rubbing when your flexing the suspension, but if you're still in break in and trying to not to beat it up too badly before the end of the warranty, then you could probably roll 33" without too much problem. I took my Ford up almost 4" in tire size over stock and the only problem is when I hit a really hard dip at speed. I would think you could go up an inch without too much trouble.
2006 Tacoma Access Cab 4.0ltr V6 TRD Offroad, 6 Speed Manly-man-mandingoness
"Too close for missiles, switching to guns."
Member #13 - no matter what that thing says.
Percy is offline
Old 02-18-2006, 07:47 PM   #8
Member Number: 83
good points corgi, and true. a good artice detailing the comparison between skiny and wide tires can be found here: http://www.expeditionswest.com/resea...tion_rev1.html
Old 02-20-2006, 12:28 PM   #9
Ducks's Avatar
Member Number: 960
I am also interested in putting on 33" tires.
I want to swap the 17" alloy wheels and 265s for 16x8 steel wheels and BFG 305/70R16. I think that is a 1.2" increase in diameter and a 1" increase in width. Is there anyway to find out if you have to do other modifications to support the tires or do you just see if they fit at the tire shop?
I haven't modified a vehicle for off-road before although I have definitely gotten stuck in the mud more than a couple of times.
Ducks is offline
Old 02-20-2006, 05:32 PM   #10
Member Number: 83
if you are going test fit the tires someplace check and see if they have a forklift so you can fully cycle the suspension with steering locked both ways and everything, front and rear. there are a lot of trucks that will fit bigger tires on pavement, but the minuet you take it through a decent pothole, not to mention off road, you will be rubbing. the backspacing on the wheels you chose has a big effect on that too, so try to find a place that will work with you on getting something that fits good.
