Can anyone provide photos of a titanium FJ on a 3" lift with these tires. The reason one size would be better recommended than the other. I understand the 295 require a BMC. By the way, both sizes will be on 70/17s. I'm almost sold on getting the 285s, but it seems like I'm seeing more people with 295s. I will be a moderate off roader in case you wonder. Thanks!!
__________________ 2007 Titanium Silver, 5 speed auto, A-Trac, RR Locker, FJ Newb's Scuba Mod. Rough Country front spacer, Rear Toytec Superflex Coils,Pro Comp ES9000 rear shocks, Nitto Terra Grapplers 285/70/17, Rear Tail Light Guards, Ricochet Skids, Trail Team Rock Rails, Spidertrax 1.25 spacers.
Doesnt matter the lift kit brand, im hoping to see how the terra grapplers look on a 3" lift. I would like to know and see how much of a difference the 295/70/17 have to the 285/70/17. Im trying to spend money but my brain has too many questions that need answering!
2mpg?? Wow didn't realize I lost so much mpg with 295... Have you ran them to compare?
You do know that most 285 tires are not even 33" tall. A 295 is 33" tall. It's a matter of a 1/2" bigger
Location: Ohio- Security isn't real by sentiment but Soldiers who have been trained in the use of Force!!
Re: 295 vs 285 Terra Grappler
Stock Tire - 285/70R17 >Search Tires Tire 1 - 295/70R17 >Search Tires
Section Width: 11.22 in 285 mm
Section Width: 11.61 in 295 mm
Rim Diameter: 17 in 431.8 mm
Rim Width Range: 7.5 - 9 in
Rim Width Range: 8 - 9.5 in
Overall Diameter: 32.70 in 830.58 mm
Overall Diameter: 33.25 in 844.55 mm
Sidewall Height: 7.85 in 199.39 mm
Sidewall Height: 8.12 in 206.24 mm
Radius: 16.35 in 415.29 mm
Radius: 16.62 in 422.14 mm
Circumference: 102.7 in 2608.5 mm
Circumference: 104.4 in 2651.7 mm
Revs per Mile: 636.0
Revs per Mile: 625.5
Actual Speed: 60 mph 100 km/h
Speedometer1: 59.0 mph 98.3 km/h
Speedometer Difference: - Speedometer Difference: 1.678% too slow
Diameter Difference: - Diameter Difference: 1.66%
I must be drunk I thought the 285- 295 was a width measurement not a height measurement? The middle number would be required to truly get the correct size of the tire. hense 285-50-20 is around 31" and 285-65-20 is closer to 35"
Ya you better stop drinking..285 is the width 70 would be the percentage of width to determine height of sidewall
What's with the 20" rim numbers? Math is to hard for me! 315/70/17 is a 35" tire
Like I said about a 1/2 bigger (9/16)
Almost 2" in circumfrence. That's not a drastic change should he regear also?
295's with a walker Evans 3.5" lift... no chop needed at that point...
scotty
President of the FJORC.org we are a Toyota based Off-Road Club between Cleveland and Pittsburg, if your in our area and looking for a club come check us out.
