10 inch or 8 inch Rims - Toyota FJ Cruiser Forum
» Auto Insurance
» Featured Product
Old 01-07-2013, 08:54 PM   #1 (permalink)
Member Number: 51934
Send a message via Yahoo to MotioncontrolMike
I was told that it was better to put 33 inch tires on 10 inch rims instead of 8(or 7.5) inch rims. Reason being is that the 33 inch tire can curl up under the rim easier if it is a 10 inch rim when airing down to traverse snow pack or sand.
Is this something everyone agrees with? Buy 10 inch rims instead of 8 inch when planning to go off road typically?
Side-Note: I could see how the 10 inch rim would give a cooler profile to the tire on the FJ...but then would the 8 inch rim be better for a daily driver?
Any thoughts?
Many thanks
Mike
MotioncontrolMike is offline
Old 01-07-2013, 08:56 PM   #2 (permalink)
lqdchkn's Avatar
Member Number: 45064
Re: 10 inch or 8 inch Rims
Tire width should determine wheel width, not height.
What size tire are you trying to run?
2012 Quicksand
View My Build
lqdchkn is offline
Old 01-07-2013, 09:09 PM   #3 (permalink)
tgormtx's Avatar
Member Number: 40295
I ran 285/70/17 (~33) on stock 7.5" wheel and had no issues what-so-ever. Discount Tire will no longer put a bigger tire than that on a 7.5" wheel. To go wider, you need an 8 or larger.
Tom | TLCA.21835 | Toyota Trail Riders
'10 Iceberg FJ 4x4, A/T, Rear Locker, A-Trac, Convenience Pkg, UpgradePkg #2, TRD Cold Air Intake, Nitto Trail Grappler 285/70/17, Black Rhino Sidewinder Wheels, MetalTech Sliders, Dual Horn, ICON Stage 2+ (Ext. Travel Coilovers w/ Remote Res., Tubular UCAs), ExpOne Diamond Bumper, Ricochet HD Skids Full, SPOD, ExpOne Windshield Fluid Reservoir, Suspension Armor
Vendors that gladly accept my money:
TRDParts4U
Demello Offroad
MetalTech4x4
Ellis Precision
Ricochet Offroad
BaerTrax
Roads? Where we're going, we don't need roads.
tgormtx is online now
Old 01-07-2013, 09:12 PM   #4 (permalink)
rubelcon's Avatar
Member Number: 60222
lqdchkn previously said: View Post
This.
rubelcon is offline
Old 01-07-2013, 09:54 PM   #5 (permalink)
I am running 33 inch tires...the point the guy was making to me...it seemed...was that a wider rim with the same tire size would give better 'cupping' when off roading when aired down...true?
For example...33 inch tire on a 7.5 inch rim vs a 33 inch tire on a 10 inch rim....one better than other for off roading when aired down?
Mike
Old 01-07-2013, 10:42 PM   #6 (permalink)
lqdchkn's Avatar
Like I said you are quoting tire height "33inches" but are asking about rim width. A 33inch tall tire can just as easily be 9 inches wide as it can 12 inches wide. Obviously if you want to run a 9 inch wide tire the 8 inch wide rim would be better, likewise if you want to run the 12 inch wide tire you're going to need the 10 inch wide rim. But you're not telling us what width tire you want to use, you only keep telling us the height "33s".
We need more info in order to properly help you.
2012 Quicksand
View My Build
lqdchkn is offline
Old 01-08-2013, 01:59 AM   #7 (permalink)
Sorry about that...I get it now. I am a little slow...Want to run a 9 inch wide tire... so i guess the 8 inch rim would be just fine(not a 10 inch wide rim tho).
thanks guys! I really REALLY appreciate the expertise on this forum. I am indebted to so many of you.
Mike
Old 01-08-2013, 04:03 AM   #8 (permalink)
weavinfj's Avatar
Member Number: 23518
Is anyone on here running a 10" wheel? That is a wide wheel. I have 9" wheels, and you can run up to a 13.50" tire on mine. I believe 10" is for 14" tire and up, which means its probably close to 40" tall! Correct?
Sent from my C771 using AutoGuide.Com Free App
mods, mods, MORE mods...blah blah blah. The list is too long...it was getting irritating
weavinfj is online now
Old 01-08-2013, 10:13 AM   #9 (permalink)
lqdchkn's Avatar
MotioncontrolMike previously said: View Post
Mike
Yup for a 9inch wide tire I'd pick the 8inch rim too. It nice to have a little meat on the sides
@weavinfj - OC maybe??, he's running 305s or 315s or something hella wide
2012 Quicksand
View My Build
lqdchkn is offline
Old 01-08-2013, 04:09 PM   #10 (permalink)
Buggy Building Moderator
FJNewb's Avatar
Member Number: 19411
Run with the 8" rims. Especially if going with a narrow tire as others pointed out. You'll have issues mounting a narrow tire on a 10" wide rim.
FJNewb is offline
