Re: Just want to double check on BMC and 285/70/17s
if you get a BMC heck yes.
you should get the tires before the BMC. You might not need the chop...Im running duratracs and there is an ever so slight rub at full lock. nothing worth getting a bmc over.
2011 NSSE - Icon coilover - TotalChaos UCA - SAW rear coils - OME 895 rear medium shocks - Metal Tech slider - Metal Tech tube bumper - Viper Elite 10k Winch - PIAA 520 ATP - Midland 75-822 CB - Boztec antenna mount - Duratrac 285/70x17 - Scuba Mod - Ricochet skids - PIAA dual horn 400/500 - sPOD - Ellis Stealth Shift Knobs - MPAC rear/side rack - PLX Kiwi Bluetooth OBDII - Nestah Edition Firestik Radio Antenna - National Luna Single Battery Monitor - Tantrum Rock Lights - Outrider Shock Armor - Toy Outfitter LCA - Switched DRL's - Front rock cameras - Custom Rear Cargo Storage - Platinum PM-1 Battery
Thanks for the reply. I'm going to get the BMC tomorrow, cause the price is right and I plan on going bigger eventually. Scheduling the tire installation for Sunday. So psyched!
Post up pictures when you get them on.
Fwiw you might be able to get enough caster adjustment out of it you wouldn't have to chop the body mount. However, if you want larger tires in the future might as well do it.
Yeah you most certainly dont need the chop for those tires with proper alignment, but it will be good to have later if you go bigger, or even add spacers
-Adam '07 Black Diamond 4WD AT UR
Bilstein 5100s | UltraGauge | Husky Liners | Yokohama Geolandar AT-S (E) - Offroad wheels | Powerstop brakes
OE Rock Rails | Ricochet Armor | Rocktek Link Armor | Midlands 75-822 - 2' Firestik - Boztec mount
Ellis Precision Shift knobs - e-brake | Discovery Overhead Console. w/ GPS In NC or surrounding states? Check out North Carolina FJs for Trail Rides and Info.
I'm running a set of 285/70/17 Toyo Open Country A/T II with NO BCM. I have no rub, even off roading, but I also haven't done any serious, hardcore trails yet.
