265 vs 285 - Toyota FJ Cruiser Forum
 2Likes
post #1 of 27 (permalink) Old 08-05-2013, 08:39 PM Thread Starter
Quoted: 17 Post(s)
265 vs 285
Hi, I'm from the Philippines. I currently have a 265/75/r16 tires (and stock FJ).
Looking for new tires, I'm torn between the stock 265/75/r16 or might try the 285/75/r16. I know that this was discussed numerous times that the 285/75/r16 tires will or not rub on stock FJ (no lift and no bmc).
1. To those who has current 285/75/r16 tires on stock fj, pls comment...
2. In terms of riding comfort, which is better, 265 or 285? (I dont go major offroading, main purpose of FJ is for everyday used and travelling)
Tires that i'm considering, all in A/T..
Nitto terra grapler
Mickey Thompson
Bridgestone
Thank you so much..
angeldavid216 likes this.
gomez_ea2 is offline
post #2 of 27 (permalink) Old 08-05-2013, 09:20 PM
Quoted: 3 Post(s)
Re: 265 vs 285
I have the 285/75/R16 Nitto Trail Grapplers on mine (2.5 inch Old Man Emu lift). The tires have about 16,000 miles on them. I love the Nitto's, they're not even close to rubbing. They are surprisingly quite for mud tires (about the same sound as the stock BF Goodrich All-Terrain's - mine came with the off-road package and 16" wheels). I do rotate the tires every 3000 miles. I've heard you get about 40,000 out of the Nitto "Trail" Grapplers and mine seem in-line with that. They seem to handle well in snow, rain, and off-road. They took me up "The Wall" at the FJ Summit in about 10 to 15 seconds. I'd give the 5/5 stars. I hope that helps.
2008 FJ Cruiser in Digital Camo (all Toyota Paint), 4x4, 6 Speed Manual, Nitto Trail Grapplers 285/75 R16 - E Rated, Expedition One Kodiak front bumper, PIAA 530 LED's, Rigid D2 LED's, LED Light Bar, Warn M8000 winch, All-Pro Rock Rails, 2.5 " OME Lift, All-Pro Skid Plates, Custom Backing Skid Plate, Off Road Package (16" Alloy Wheels, Cyclone Air Pre-cleaner, A-TRAC, Locking Rear Differential, Multi-Information Display), Convenience Package, OEM Roof Rack, OEM Heavy Duty Floor Mats.
Rich
richbradbury is offline
post #3 of 27 (permalink) Old 08-05-2013, 09:27 PM
CurbCrawler's Avatar
Quoted: 97 Post(s)
Re: 265 vs 285
Man-up & go with 285's & trim the body mounts, you don't need a lift, but leveling the front (add 1") is a nice option.
The reason why we retain memories is because we are not caught in a time loop. The reason why we are not caught in a time loop is because it is not possible to go backwards in time only forward!
*CurbCrawler fabricated hidden front receiver.
*CurbCrawler fabricated Hi-Lift receiver mount.
*CurbCrawler fabricated SS dual battery tray & Walmart Battery.
*CurbCrawler fabricated 4-Gauge dash pod.
*CurbCrawler fabricated Aux fuse/relay panel.
Gibson cat-back exhaust (Dyno Proven)
Complete set of aluminum skid plates.
Receiver mounted 9k-lb rear winch.
Hayden trans cooler w/electric fan.
Factory rock rails.
Moon roof.
LED fog & backup lights.
Husky mats: front, center & rear.
CurbCrawler is offline
post #4 of 27 (permalink) Old 08-05-2013, 11:45 PM
mach1dsg's Avatar
Quoted: 170 Post(s)
Re: 265 vs 285
I run 285/75/16's with no BMC, enough clearance to run them without cutting anything, 2.5" lift with Bilstein 5100's front and 1.5" rear spacer for a level look.
2010 SFM, M6, URD Short Shifter, Radflo 2.5 Ext CO's/650lbs springs, Toytec RCC2.0 Springs/OME 60071L, Light Racing UCA's, Skyjacker SBE702 links, Metaltech Front Bumper, Badland 12k Winch, Metaltech LCA's, Trail Gear TC Skid, AllPro HD Sliders, Allpro IFS/Trans/Lower Link Skids, Ricochet LCA skids, Boztec Diff Skid, 16" TRD Wheels, 1.25 Spidertrax , Firestone Destination MT 285/75/16, PIA 520's, Hella 700's, 3" PODs, 42" Led Bar
My Build
mach1dsg is offline
post #5 of 27 (permalink) Old 08-06-2013, 12:50 AM Thread Starter
Quoted: 17 Post(s)
Re: 265 vs 285
So, its safe to get a 285/75/16 with no rubbing issues on stock FJ. (no lift and no BMC)
(no plan on lifting the FJ and BMC, its a everyday car for me, what I like about the FJ is it give you the power you need on highway (for an SUV) and no need to slow down on small holes and bumps compared when I'm using a car)
How about the riding comfort of the 285/75/16? Is it noticeable compared to 265/75/16 (like heavier, bouncy ...). Or just the same?
tia..
post #6 of 27 (permalink) Old 08-06-2013, 01:34 AM
Quoted: 671 Post(s)
Re: 265 vs 285
Honest advice!! Why are you considering going to the larger tire?? if you have no plans on lifting the vehicle and have no need for any addition ground clearance I think you should stay with the stock 265 size tire, they will be cheaper to purchase, look better than the 285 at stock ride hight and roll down the road slightly easier not effecting your gas milage and a little softer ride.... All stock appearance and it is your every day driver and transportation I see no benefit to you by increasing the tire size. There is nothing wrong with rolling a completely stock Cruiser.
Cheers.
WaJohnZ is offline
post #7 of 27 (permalink) Old 08-06-2013, 02:37 AM Thread Starter
Quoted: 17 Post(s)
Re: 265 vs 285
WaJohnZ previously said: View Post
Cheers.
Wow!, thanks for the advice!! Actually i'm just looking for other options aside from having a stock tires. The pros and cons of having a stock 265 vs to upgrade to 285. If there is no advantage of having 285, ill stick to 265..
post #8 of 27 (permalink) Old 08-06-2013, 06:23 AM
BacktoFutureToyota's Avatar
Quoted: 20 Post(s)
Re: 265 vs 285
IMHO I went from 265 BFgoodrich ATs to 285/75/16r Nitto Trail Grapplers. 3 inch lift, TC UCAs, no BMC, daily driver. The Nitto's are awesome as a previous poster stated and they can get your through a lot. They look aggressive and fill in the wheel wells like no other. They also will last you a long time. The downside is that they are among the heaviest of 285 available. If you don't have a good mechanic to properly balance your going to get a lot of road noise. Your also going to see a loss of mileage. I agree that if this is your daily driver and you have no intent of going off road or anything harsh...stay with the 265s (maybe a more aggressive pattern). The BFGs were fantastic for me and handled, sounded great.
BacktoFutureToyota is offline
post #9 of 27 (permalink) Old 08-06-2013, 04:58 PM
mach1dsg's Avatar
Quoted: 170 Post(s)
Re: 265 vs 285
wajohnz previously said: View Post
honest advice!! Why are you considering going to the larger tire?? If you have no plans on lifting the vehicle and have no need for any addition ground clearance i think you should stay with the stock 265 size tire, they will be cheaper to purchase, look better than the 285 at stock ride hight and roll down the road slightly easier not effecting your gas milage and a little softer ride.... All stock appearance and it is your every day driver and transportation i see no benefit to you by increasing the tire size. There is nothing wrong with rolling a completely stock cruiser.
Cheers.
+100
My Build
mach1dsg is offline
post #10 of 27 (permalink) Old 08-06-2013, 06:58 PM Thread Starter
Quoted: 17 Post(s)
Re: 265 vs 285
Thank you guys for your advices!. I'm just looking for new set of tires aside from being stock ( i thought wider tires might look better and bad ass than the 265), but if there are consequences, i might stick to 265.
I used my fj as daily driver, and like what I've said, what I like about the fj is the power you get for an SUV size (although not that comfortable). I prefer it driving fast rather than heavy offroad. If this will compromised by having a wider tires (285), i think 265 will better suits my daily need. I might just get the Nitto Terra Grapler or Mickey Thopson.
Human Verification
