SHP previously said:
1) Don't get steelies because "you can't ballance them"; and
I think I know where this comes from.
Brand new OEM, and new out of the box steel rims should ballance fine as long as they are made well. If you drive on the street all the time they should always ballance just fine.
Problem comes when you air down and go off-road.. realy off-road, as in over rocks, big ruts, etc, while aired down and I'm not talking a graded dirt back road. Steel rims bend and/or warp real easy if impacted and/or bounced hard off-road. Alloy's are actually much much thicker and stronger. If you hit an alloy hard enough to break or crack it, you would have more than destroyed a steel rim doing the same thing, so I don't want to hear somebody whine about alloy rims break. I ran steel rims for ages, and they always bent or warped pretty quick and became impossible to ballance. The only advantage of a steel rim is they are cheap. The alloy's used off-road will not bend or warp, and are much lighter. Look at most of the off-road trucks and rock crawlers. How many of them are running steel rims? Not many at all. Almost all are running alloy wheels with or without bead locks.
And then there is the argument you can bend a steel rim back if you dent it off road. I was able to only do that once where the bead leaked where the rim got bent, we were able to hammer it back and seal it enough to get home. But the rim was still trashed and had to be replaced, I could have just as easy put the spare on instead of hammering on it.
So there is some basis to that statement. If you are a street driver, it's false. If you realy use them off-road, it's true.
