Old 03-19-2007, 01:36 AM   #1 (permalink)
Member Number: 8295
Wheel sizes?? How big w/o lift.
OK, so I think I'm gonna put on the Donahoe Racing Suspension kit, but since I live in NYC, I won't be lifting and I prefer not to trim or change bumper, etc. What's the biggest tire I can get on there using stock 17"'s?
I've searched, but it seems like as often as this comes up, people are always lifting or trimming, etc.
trd exhaust, trd intake, toyota skid plate, custom sound system incl. 2x10 Wicked Cas sub enclosure, predator step bars, custom front fogs, rack mount rear lights, billet grills
The Worm Guy is offline
Old 03-19-2007, 02:49 PM   #2 (permalink)
fivestar13's Avatar
Member Number: 6657
Location: currently Huntsville, AL, originally from Honolulu
Re: Wheel sizes?? How big w/o lift.
Well I believe you'll really enjoy those donahoes. but onto your question. I think you'll find the consensus here is 285-70/17's will be the biggest without trim or any issues. You can search high and low, but some have found success with that size without trimming others have not.
Good luck!
- Chris
TLCA # 16780
2007 FJ: Voodoo Blue, AT w/ CQ UR2, FJ Roof Rack, Factory rails, hitch, skid plate,TRD intake + exhaust, ScanGaugeII
885/895 OME Lift, OEM black steelies
Smokey Mountain Cruisers
fivestar13 is offline
Old 03-19-2007, 03:19 PM   #3 (permalink)
FJ4Jake's Avatar
Member Number: 7298
+1 that size tire should fit with the stock wheels... you might get into trouble with an aftermarket wheel depending on its width and backspacing...
FJ4Jake is offline
Old 03-19-2007, 04:39 PM   #4 (permalink)
Clwtr FJ's Avatar
Member Number: 6159
This past weekend I mounted 275/70/17 Goodyear Wrangler MT/R's on my BBS rims. No worries what so ever and they look freakin' great!!! I would say 275 is the limit if you do not want to install a lift or do any mods. I will post pics soon. Good luck!
Roger that
Clwtr FJ is offline
Old 03-19-2007, 05:59 PM   #5 (permalink)
nuberton's Avatar
Member Number: 7499
Send a message via Yahoo to nuberton
I tried to get ahead of the game and got fitted for 285/70/17's (BFG KO's)today but they rubbed on the frame right behind the wheel. The Donahoe's are in the mail as we speak; is that gonna alleviate the problem?
nuberton is offline
Old 03-19-2007, 06:38 PM   #6 (permalink)
wakesurfboy's Avatar
Member Number: 574
I don't understand why people here get some problem with 275 or even 285 because I just finish a test with a MTZ 33 12.5 /17 (305/65/R17) on stock alloy!!!!
They rub on the plastic protector of the body mount only if I remove it, no rub on the frame or UCA???
I believe if you change the wheel for another size (more then 7.5” rim) and backspace (<> 4.5”) or add spacers it will generate body mount problem.
For lift, I conclude that a 2" lift on front don't make a big difference because of lot of reasons.
To be sure of what I told you here, let me test the setup and I will post my final test result in 2-3 week.
[i]Darth Cruser, Warn Rear & front bumper + 9.5ti, MTZ 33 x 12.5 /17 and the fantastic King shocks kit!
wakesurfboy is offline
Old 03-19-2007, 06:40 PM   #7 (permalink)
Member Number: 8328
The Worm Guy previously said: View Post
This depends on the tires you put on is what I found. I have read that the Nitto's at 285's do not rub without a lift or any cutting. You "might" have to trim some plastic, but tha'ts nothing. I have 285's on order and I'm not lifting based on what I read here, so I hope they don't rub
FJ4GD is offline
Old 03-22-2007, 04:42 PM   #8 (permalink)
Member Number: 8328
FJ4GD previously said: View Post
Now for the real deal...they do rub and now I have to lift my FJ. I treid to get them installed today, and no go...too much rub.
I was installing the MM 951's with Nitto 285's...
FJ4GD is offline
Old 03-22-2007, 08:44 PM   #9 (permalink)
daPitbull's Avatar
Member Number: 9386
Prior to lifting, I was running 285/70/17 Hankook Dynapro MT on stockers. Minor rubbing on the plastics covering the body mount. Now that it's lifted, no rubbing at all. However, I still plan on doing the body mount chop.
daPitbull is offline
