Old 03-22-2007, 07:34 PM   #1 (permalink)
Toyotatech1's Avatar
Member Number: 1637
Send a message via AIM to Toyotatech1
20" wheels with OME Lift
Anyone have 20" wheels with a 3" OME lift kit? Just recently installed this setup on a stock unit and I am having a problem with the top of the tire rubbing on the front of the control arm on say a u turn or steering wheel all the way locked to one side. Tried a 1/2" spacer no help. Will post pics tomm might have to go down to say 18" wheels.
Toyotatech1 is offline
Old 03-22-2007, 07:49 PM   #2 (permalink)
ADH
ADH's Avatar
Member Number: 8496
Re: 20" wheels with OME Lift
Get some aftermarket UCAs like TC, Camburg, Allpro, etc. You'd get better steering response, and it would probably be cheaper than new rims and tires. This is, of course, assuming that your current tires and wheel backspace aren't causing so much rub that even new UCAs wont help. You will generally find, however, that many of the aftermarket products provide much more clearance for larger tires.
_____________________________________________
Titanium, 4x4, MT, OEM Rack and Skid, Package 2,
TRD Exhaust, TRD CAI
TRD Rims, BFG All-Terrain KO 285/75/16
Donahoe front CO, Total Chaos UCA, Toytec Rear coils, OME rear extended shocks
ADH is offline
Old 03-24-2007, 03:12 AM   #3 (permalink)
J-Rock!'s Avatar
Member Number: 9382
Toyotatech1 previously said: View Post
What size tires are you running? Specs on the wheel such as width & backspacing in inches? I'm thinking about going w/20's as well.
Jimmy
07' GSJ-10 1GR-FE - Slightly modded for the streets. The closes thing to offroading I'll ever do is go over a curb!
08' E92 S65B40 (M-DCT) - Weekend cruiser...Got Volk Time Attack?!?
J-Rock! is offline
