Old 03-23-2007, 08:18 AM   #1 (permalink)
FJuggernaut's Avatar
Member Number: 5271
Make your AR center caps fit your wheels – HOW TO
As with most others around here, my center caps for my American Racing rims wouldn't fit because of the hub centric design of the factory wheels. The AR caps are supposed to go on from behind when you mount the wheel. This just won’t work for us.
This lip is the problem:
So what to do? I went to work on them with my dremel tool and cut the lip off. I removed the rubber band and used its channel to guide/cut the lip off.
The plastic will melt a little and give you some build up. This is easily chipped off by hand or you can use some sand paper or other means.
A test fit on the wheels instantly proved that they fit. They were snug, but would most likely come flying off at speed, so I decided to put the rubber band back on.
I built up my dremel tool’s width with three cutting disks. I am sure there is a tool out there that would do this cleaner and better, but I have a “problem solving brain” so I went with the dremel method.
I cut a new channel into the cap all the way around about .5 cm in. You will have to cut the channel pretty deep to seat the rubber band deep enough to get the cap wedged into the wheel, more on this later. If you cut too deep don’t worry, it doesn’t have to be perfect. If your OCD kicks, take your meds, and you will be fine. It will take some slow work and finding the right technique, but eventually you will figure out how to groove the channel. I figured it out on the last one!
Like the first cut, the plastic melts and builds up. Most can be removed with your hand, but I used a brush from my dremel set to clear the channel away.
Put the rubber band back on and approach your vehicle slowly! Mine seems to be wary about sticking things in unused holes.
You will have to initially work them in by hand until the rubber band is all the way in the wheel, then I needed a mallet/dead blow to get them all the way seated. Be careful and start slowly. Some lubrication might be needed, but I managed to get them on without it. I would caution someone to use anything that wouldn’t evaporate because you probably don’t want these coming out because of a lubricant. Maybe try some saliva? Work the mallet around the edges, the middle of the cap is covered with a thin metal logo piece that will bend and come of if you hit it (experience speaking here). Just work the mallet around the edges until it is seated all the way back in the hole.
I have had them on the vehicle for several weeks, just haven’t had time to write this up. I checked them ever so often and they haven’t budged a mm. Sorry I will post pics of them on the vehicle later, my camera phone just doesn’t cut it.
Hope this helps everyone out with this problem.
Dax
Black Diamond - 4x4|6MT|CQ|UP#1|GY - 37607
Stuff
FJuggernaut is offline
Old 03-23-2007, 08:56 AM   #2 (permalink)
Cruz's Avatar
Member Number: 6127
Re: Make your AR center caps fit your wheels – HOW TO
Thanx for the write up. But I pretty much just gave up on the caps for my Chambers & painted the center part of the rear hubs black. Taped off the center of the wheels & gave it two coats of high temp grill paint...pretty simple...but I'm lazy.
07 TM A/T 4x4
OME / All-Pro / TRD / AR / MT
Cruz is offline
Old 03-23-2007, 09:01 AM   #3 (permalink)
RenoMan's Avatar
Member Number: 1114
AR does make caps that fit the FJ, you just have to specifically request them when you purchase your wheels. The people at wheelsforless.com were already aware of this when I ordered mine, so it is good to know that the information is seeping out there.
FJ Cruiser 4703, UP1 CQ & GY, 2Q, Gobi Stealth, PIAA lights, Donahoe front and rear lift, AR Victor Teflon Wheels, 285/70R17 Hankook MT's, Demello sliders, Exp-One bumper, Superwinch 9000 w/ synthetic
WISH LIST - Aux. Fuel Tank, Dual Battery
Pub for wife's store - http://www.vino100-reno.com/
RenoMan is offline
Old 03-23-2007, 09:09 AM   #4 (permalink)
Cruz's Avatar
Member Number: 6127
I didn't have any fitment issues w/ mine I just didn't like the way they looked. For one they stuck out too far & two they were more of a gunmetal color as opposed to the teflon finish that is on the wheels.
07 TM A/T 4x4
Cruz is offline
Old 10-08-2007, 06:31 PM   #5 (permalink)
ironmind's Avatar
Member Number: 380
RenoMan previously said: View Post
Anyone have a part number on the correct caps yet?
master bullshi++er
ironmind is offline
Old 10-08-2007, 06:41 PM   #6 (permalink)
RenoMan's Avatar
Member Number: 1114
ironmind previously said: View Post
I believe there are a few part numbers, depending on if you want black or chrome(like). If you call up the guys at wheelsforless.com, they can probably direct you in the right direction.
RenoMan is offline
