Old 03-29-2007, 02:27 PM   #1 (permalink)
spincycle's Avatar
Member Number: 9041
Size Advice w/3" OME Lift
So I'm about to install a 3" OME lift to help accomodate front & rear Warn bumpers & winch. At the same time, I'm also planning on swapping out the silly stock tires (which have all of 400 miles on them!) for BFG AT KO's.
I'd like to run 'em a little wider - 285's, say - and a little taller, but I'm not entirely sure, after reading previous posts, just how tall I can reasonably expect to go without either undue rubbing (without cutting metal) or handling/gearing issues.
Anyone with a similar setup have any advice? Any input appreciated.
TLCA#17822 / FCC:KD0ECN
'07-6MT-FJC...and a whole BUNCHA stuff.
My thanks to Budbuilt, Lucrum, URD, Tuffy, Springtail, KC, BFG, Valentine One, Cobra,
Engel, BFG, Cobra, Yaesu
Protest the end of poitical dialog by contacting
your favorite moderator(s)!
spincycle is offline
Old 03-29-2007, 02:30 PM   #2 (permalink)
fivestar13's Avatar
Member Number: 6657
Location: currently Huntsville, AL, originally from Honolulu
Re: Size Advice w/3" OME Lift
Given what you are about to do...lift, etc. A 285 size BFG KO will fit comfortably with no cutting. Sure maybe 295s can squeeze...not sure if tire avail. in that size anyway...but I think you'll be happy with 285s mounted on your rig once lifted with OME suspension.
Good Luck and do post up your results!
- Chris
TLCA # 16780
2007 FJ: Voodoo Blue, AT w/ CQ UR2, FJ Roof Rack, Factory rails, hitch, skid plate,TRD intake + exhaust, ScanGaugeII
885/895 OME Lift, OEM black steelies
Smokey Mountain Cruisers
fivestar13 is offline
Old 03-29-2007, 06:15 PM   #3 (permalink)
hero's Avatar
Member Number: 4576
Send a message via AIM to hero Send a message via MSN to hero Send a message via Skype™ to hero
I am running with OME and Wrangler Silent Armor 285s no problem.
20070224 Random Drive
"If you insist on getting credit for the work you do, you'll never get far in life. Don't confuse yourself with the idea of getting credit"
- Colonel John Richard Boyd, USAF, retired.
- Mike
hero is offline
Old 03-29-2007, 06:18 PM   #4 (permalink)
Member Number: 8458
ditto above advice i am fixing to do the same thing and run the 285/70/17 cooper discoverer stt's. can probably squeeze the 295's but will ultimately have to chop the body mounts.
dph5002 is offline
