Old 03-30-2007, 02:22 PM   #1 (permalink)
jdd22's Avatar
Member Number: 9677
Tire Size on 16" wheel?
What is the best or biggest tire size on a 16x8 wheel? No lift, no cutting, no rub etc... Just a stock Cruiser. The TRD model runs a BFG 285x75x16 stock? Shouldn't this work for my FJ?
Thanks, J
jdd22 is offline
Old 03-30-2007, 02:45 PM   #2 (permalink)
Mtbcoach's Avatar
Member Number: 2433
Re: Tire Size on 16" wheel?
jdd22 previously said: View Post
Thanks, J
Stock tires are 265/75/16 or 265/70/17 depending on the wheel option you pick.
Best or biggest? I thing best is 255/85/16, others have their opinion of "best".
Biggest? Some have reported running 285's without rubbing and some report rubbing. It all depends on the manufacture of the tires and the tread pattern. More aggressive treads "tend" to rub more than street tires.
Take the time to search through the tire and wheel thread and you will find many options to pick from as well as the opinions as to which tire is "best" and "biggest".
Demello sliders
Demello rear bumper
Inchworm Lefty
ARB front air locker
Nitro 4.88 gears
Bud Built skids front to back
Super Swamper SSR 35 X 10.5
Safari Snorkel
Train Hard, Rest Harder
TLCA # 17784
Mtbcoach is offline
Old 03-30-2007, 04:20 PM   #3 (permalink)
BellyDoc's Avatar
Member Number: 9768
The "best" tire is a question of what you want it to do! There is no tire which does everything the best. They're either better on the road or better on rocks, or better in mud... what do you want your tire to do?
A well posed question suggests it's own answer!
-Jon-
BellyDoc is online now
Old 03-30-2007, 04:28 PM   #4 (permalink)
jeshua's Avatar
Member Number: 6888
I have 285/75/16 BFG AT and my driverside rubbed. I choped the mount so no issues. And like the others of said "the best tire" is mostly personaly prefrance and what you it will be used for.
Mike Ambs
www.corva.org
- Thomas Paine
Aequitas - Veritas
jeshua is online now
Old 03-30-2007, 04:33 PM   #5 (permalink)
ADH
ADH's Avatar
Member Number: 8496
I had this too, until I lifted. No rub since (although I think it may still be possible to rub in a certain circumstance).
_____________________________________________
Titanium, 4x4, MT, OEM Rack and Skid, Package 2,
TRD Exhaust, TRD CAI
TRD Rims, BFG All-Terrain KO 285/75/16
Donahoe front CO, Total Chaos UCA, Toytec Rear coils, OME rear extended shocks
ADH is offline
Old 03-30-2007, 06:02 PM   #6 (permalink)
cnynrat's Avatar
Member Number: 8138
The stock tire on the regular FJ is 265/70R17. If you go to a 16" wheel, a 265/75R16 will be the same width and overall diameter. You should not have any rubbing on a stock FJ with either of these wheel/tire combos.
A 275/70R17 size tire will also fit and I've not heard any reports of rubbing with this size tire. You have limited choices though - the Goodyear Wrangler Silent Armor is the only AT tire I am aware of in this size. It's supposed to be a good tire though if that's the way you want to go. I am not aware of any 275/75R16 sizes, but they could be out there.
If you go to a 285/70R17 or 285/75R16 I think you run the risk of rubbing - seems like most people report that these tire sizes rub on their body mounts under some conditions even if lifted, but there are exceptions.
Someone with a TRD will need to confirm, but I thought the TRD came with 265/75R16's.
Dave
Member Tread Lightly
Ti Metallic
cnynrat is offline
Old 03-30-2007, 06:38 PM   #7 (permalink)
Mtbcoach's Avatar
Member Number: 2433
The FJ Cruiser TRD SE comes with "grey" 265/75/16's...
Demello sliders
Demello rear bumper
Inchworm Lefty
Nitro 4.88 gears
Safari Snorkel
TLCA # 17784
Mtbcoach is offline
Old 04-01-2007, 07:14 PM   #8 (permalink)
jdd22's Avatar
Member Number: 9677
Perfect, thank you.
jdd22 is offline
Old 04-03-2007, 06:20 PM   #9 (permalink)
PERUANOFJ's Avatar
Member Number: 9046
I No Have Any Problem With Bf 265/75/16
NO LIFT
PERUANOFJ is offline
Old 04-04-2007, 06:47 PM   #10 (permalink)
jfoobar's Avatar
Member Number: 8649
I only ever noticed my 285/70-R17 BFG ATs rubbing once in the several weeks between putting them on and getting my lift put on, and the rub was very brief (less than a second).
"They responded to the other point of view with a recently invented little noise, something between tsk-tsk-tsk and hissing. It's the noise the kind of people who own more than one cat make when the kind of people who own more than one gun light cigarettes indoors." - P.J. O'Rourke
Visit us online at http://www.FJBruisers.org
jfoobar is offline
