TOYO Open Country AT 285/70 R17 - Toyota FJ Cruiser Forum
post #1 of 24 (permalink) Old 04-19-2007, 05:45 PM Thread Starter
Quoted: 1 Post(s)
As long as I get a 3" lift, these should fit just fine, right?
It's down to these, the Revos, or the BFG AT KO's.
athos is offline
post #2 of 24 (permalink) Old 04-19-2007, 05:50 PM
Landrover's Avatar
Quoted: 9 Post(s)
Re: TOYO Open Country AT 285/70 R17
Any tire in that size will fit with a 3" lift, although if you do some off-roading you still might need/want to do the body mount chop to make sure there is no rubbing.
Landrover is offline
post #3 of 24 (permalink) Old 04-19-2007, 06:00 PM Thread Starter
Quoted: 1 Post(s)
Ugh, I don't want to **** with the body mounts -- should I go down to 275 then?
athos is offline
post #4 of 24 (permalink) Old 04-20-2007, 09:07 AM
Kyle Dreaden's Avatar
Quoted: 1 Post(s)
I didn't want to chop either.
I was looking at a set of Toyo Open Country MTs but when I found out the only size I could get that would fit a 17" wheel was 295s, I had to change my plans rather extremely.
I'm now going to end up doing a set of Open Country MTs at 275/70/18.
I know that 18" wheels are a no-no off road but I don't think it will be too much of a problem in real world situations, considering my wheeling is pretty tame stuff.
THE VEHICLE: 2007 Titanium Metallic FJ Cruiser - AT 4x4 aka BRUISER
SUSPENSION: OME/ToyTec 3" - N140S Front Shocks, 885 Medium Front Coils, N71E Rear Shocks, ToyTec Custom Rear Coils
TIRES: BFG M/T KM2285/70/17 on Stock Alloys
EQUIPMENT: (4) PIAA Lights - Roof Racked, OEM Sliders
Kyle Dreaden is offline
post #5 of 24 (permalink) Old 04-20-2007, 09:10 AM
goodlifesearcher's Avatar
Quoted: 0 Post(s)
How long should it take toyota to install the tow hitch to my fj?
I JUST DONT WANT TO GET RIPPED OFF.
I DROPED IT OFF TWO HOURS AGO AND STILL NO CALL
goodlifesearcher is offline
post #6 of 24 (permalink) Old 04-20-2007, 09:13 AM
fivestar13's Avatar
Quoted: 0 Post(s)
Landrover previously said: View Post
athos previously said: View Post
Keep in mind, results may vary. Some have discovered that trim was necessary, others in fact did not. I have OME lift with 285 mud tires, with no trim required. Even flexed, my tires have clearance.
Kyle Dreaden previously said: View Post
Don't sweat the 18 inch wheels. However, I thought you could get the open country MTs in 33 inch sizes?
Some have gone with 295 MTs, but a chop was in order.
- Chris
TLCA # 16780
2007 FJ: Voodoo Blue, AT w/ CQ UR2, FJ Roof Rack, Factory rails, hitch, skid plate,TRD intake + exhaust, ScanGaugeII
885/895 OME Lift, OEM black steelies
Smokey Mountain Cruisers
fivestar13 is offline
post #7 of 24 (permalink) Old 04-20-2007, 10:05 AM
Quoted: 1 Post(s)
fivestar13 previously said: View Post
Yeah, I think the 18's are going to be more than fine.
I'll be honest, as new as I am to wheeling/modding, I don't fully understand the sizing standards for tires/wheels. From what I understand, the 285/275/etc. number in the front of a tire size spec refers to the width of the tire. I know that a 285 will fit without trimming on most tires, and I know that a 295 and a few up can fit with trimming. However, the tire I'm interested in doesn't come in a 285/70/17 or 285/70/18. It does, however, come in a 295/70/17, and a 275/70/18. With that in mind, I decided to go with the 275's on 18" AR teflon Chambers (or thugs if I can find some soon).
I also noticed that on tirerack and some of the others, the tire sizes available are listed with some in the 285/70/17 format and some in 33" etc. formatting.
I know what will fit in the first size spec standard, but what can I put on as far as the inches measurement standard?
post #8 of 24 (permalink) Old 04-21-2007, 07:59 PM
446cube's Avatar
Quoted: 0 Post(s)
A 285/70-17 comes out to 32.7 inches, but give or take depending on brand. Usually you'll see 33/12.50-17, which is wider than a 285/70-17.
Why not just get the 285's? If you have any rub at all, it will be at almost full articulation and not bad. I was running 285's with no lift for months with only the slightest rubbing at full articulation. Now that I'm lifted I haven't had any issues. I plan on going to 35's and dealing with a little bit of rubbing, fwiw.
446cube is offline
post #9 of 24 (permalink) Old 04-23-2007, 01:07 PM
OffRoad Rage's Avatar
Quoted: 0 Post(s)
If you keep them on stock rims you won't have a problem with a 3" lift. I think the people that have issues with the body mount rubbing have upgraded to wider rims or rims that have a different offset. I'm partial to the 285/70-17 Nittos myself (same green tire as the Toyos). They have never rubbed and I've even put mine on the RTI ramp recently for a full rub check. Trust me they would have rubbed by now.
"I AM my own worst enemy."
'12 TT Radiant Red w/ 3.0" Icon front, Fox 2.0 rear, TC UCAs, ToyTec Superflex, Ivan Stewart TRD rims, Nitto TG's 315/75/16, Demello and AllPro bumpers, 4+ Skids, MT kickout sliders, custom rock lights, AP lightbar. - The addiction continues . . . .
'07 Black Diamond w/ Daystar 2.5", 315/70-17 MT MTX's, Stock Steelies, BMC, LCA Sliders, Toytech superflex springs- Simple but effective -SOLD.
OffRoad Rage is offline
post #10 of 24 (permalink) Old 04-23-2007, 01:48 PM
4XX4's Avatar
Quoted: 1 Post(s)
Have you considered a 16" rim? If you are thinking 18, you must be getting new wheels anyway. You may find more selection w/o chop and get the width tire you want. JMO
Blacksand Beast.
El Toro Rojo
http://www.fjcruiserforums.com/forum...toro-rojo.html
FJC Club ( Creepin' n Climbin')
Aloha FJ Cruisers (Wheelin' in paradise)
SoCal FJ Cruisers tag-a-long
4XX4 is offline
Human Verification
