Old 06-12-2007, 01:33 PM   #1 (permalink)
JPness's Avatar
Member Number: 11697
Road vibration over 60mph
Just got a new set of Nitto Terra Grapplers (same size as OEM Dunlops)...brought the truck back to the tire place because of vibration at speeds over 60mph. Nothing horrible, but definitely noticable with visible steering wheel shake...should I expect this from a/t tires?
The shop said the balance was off and they rebalanced all tires, but it's only slightly better.
Any advice out there? tia
JP
Basic: Titanium Silver, conv package, upgrade 1, all-weather mats & towing package.
Mods: DO Hybrid Sliders, OME Medium setup, 16" Konig Countersteer Offroads, Nitto Terra Grapplers 285/75R16, blacked out front bezel
JPness is offline
Old 06-12-2007, 01:37 PM   #2 (permalink)
MJSFJ's Avatar
Member Number: 1642
Re: Road vibration over 60mph
Same problem here. I've recently taken mine in and had them balanced. This has fixed the problem for now. One of my coworkers had them on his Dodge Ram and just replaced them with BFGs. He never could keep his balanced.
MJSFJ is offline
Old 06-12-2007, 01:46 PM   #3 (permalink)
taltyman's Avatar
Member Number: 10097
Send a message via Skype™ to taltyman
So is this the same shop that was supposed to have balanced them in the first place? Maybe time to change shops. If they are vibrating now it will only get worse with time. If they still have your old tires maybe get a refund and put the old ones back on just long enough to get to another tire shop.
Follow the yellow brick.
Sun Fusion AT, bunch of factory options, protective door sills, multivex mirrors, reflective tape, BudBuilt front skid, Bandi mount, Midland CB, 4' Firestick
Where I live
Everything I post is for entertainment purposes only. Any comments about anything political is not intended to be.
taltyman is offline
Old 06-12-2007, 01:49 PM   #4 (permalink)
daPitbull's Avatar
Member Number: 9386
I had Nitto Terra Grapplers on my 03' 4runner and did not have any vibrations. Sounds like the tire shop isn't taking there time balancing the tires.
daPitbull is offline
Old 06-12-2007, 01:55 PM   #5 (permalink)
JPness's Avatar
taltyman previously said: View Post
Yea, I'm thinking these guys aren't exactly pros. Pretty poor service so far. That's what I get for going to the cheapest guys.
JPness is offline
Old 06-12-2007, 02:46 PM   #6 (permalink)
FUN_MACHINE_90's Avatar
Member Number: 11007
Location: New York City...Well in a burough called Staten island that no one knows about.
Send a message via AIM to FUN_MACHINE_90
hey man i got the nittos too....go to the toyota shop if they allow you to and get them ballenced there...they did it for me.
BLak Cherry...DRL's OFF...TRD CAI...JBA Evol Exhaust...IPF Magic Bulbs...All Pro Air Dam with 4 PIAA 540's, 2 driving and 2 fog.
FUN_MACHINE_90 is offline
Old 06-14-2007, 07:54 PM   #7 (permalink)
Banned
Sun Fusion Cruiser's Avatar
Member Number: 3655
I've had problems with mine too. Got them at 4WP, and noticed it right away. Took it to discount tire to get them rebalanced, but not much better. They also managed to put some knicks in my new wheels though. But since they will be offroad eventually, I am not too worried. It was bound to happen.
Anyways, the guy at DT thought it was the new wheels, since they are wider than stock. I think it is becuase 4Wp used too many damn weights in the wheels. I have 14 weights just on my front passenger tire. I heard that they should rotate the wheel 180 degrees on the tire and remount them and try to balance again. I'm gonna call 4WP tomorrow and tell them what's up. I got a tire warranty with them, so they might have to replace them.
Sun Fusion Cruiser is offline
Old 06-16-2007, 08:15 AM   #8 (permalink)
kinglenario's Avatar
Member Number: 3586
check out the Tire Balancing Fix
http://www.fjcruiserforums.com/forum...ix-sticky.html
kinglenario is offline
Old 06-16-2007, 08:32 AM   #9 (permalink)
Pacific Coast Moderator
uphill's Avatar
Member Number: 10461
I was at Donohoe Racing last week, talking about suspension and tires. They highly recommend the Nitto Terra Graplers and use them on their racing FJ that won the Baha 500 and came in second on the Baha 1000 (or maybe I have it backwards). Anyway, we were talking tire construction, etc. and I think it's less likely that it's the tire and more likely where you had it installed and balanced.
Remember that Nitto is new to the tire manufacture business. Toyo used to make their tires for them and now Nitto is making their own (in Georgia). Since you aren't matching tire conicity to the rim when the replacement market tires are installed, it will (almost) never be as good as the OE in that respect.
Tires are manufactured by assembling components made of rubber, fabric cord and steel wire that are cured together in a mold. Under intense heat and pressure during the curing process, the rubber reaches a near liquid state before vulcanization takes place finalizing the tire's exact size, structure and shape.
If a tire's internal components are misaligned as it cures, it is possible that unequal internal forces may cause the vehicle to pull to the side, even when it is steered straight ahead. When this occurs with a brand new tire it is typically due to conicity, a manufacturing glitch where a tire's tread has cured slightly cone shaped rather than in the desirable uniform cylinder shape.
OE tires are CAREFULLY matched to the rims they're mounted on based on conicity factors (note the red/blue dot on the OE tire - chalk marks across the tread in white or green). When you buy replacement market tires, you should look at the age of the tire (it's on the tire by week and year of manufacture, for example 0107 would be the first week of January 2007). If it's over a year old, don't buy it.
Likely it is the mounting and not the tire in the case of Nitto. There are a lot of other brands of tires out there for off-road applications that are just not very good. Tires vary based on the material used to construct them, the engineering of the tire itself and the care given the tire as it is stored and distributed before you ever see it.
Just my .02 cents worth on this.
uphill is offline
Old 06-16-2007, 11:41 AM   #10 (permalink)
Banned
Member Number: 3655
Got 4WP to fix them. It was obviously balanced wrong. They still used a chitload of weights, but it drives like new.
Now on to the crap part of my day. After getting them fixed, I picked up a rather large nail on the way home in my rear tire. And to top it off, it's not holding any air at all. Sometimes you get lucky and it will, but I don't have that kind of luck.
I am so depressed right now, words cannot describe.
