Old 06-18-2007, 04:13 PM   #1 (permalink)
barralf's Avatar
Member Number: 12105
Send a message via Yahoo to barralf
Thumbs up Bfg 255/75r17
I just got my new FJ Cruiser and I want to change the tires for a BFG 255/75R17 MT. those tires are just half an inch bigger.
After the down payment I can’t get my FJ lift. Did someone have problems with those tires without lift?
Thanks in advance
Fernando
barralf is offline
Old 06-19-2007, 12:40 AM   #2 (permalink)
Z'sFJ's Avatar
Member Number: 11320
Re: Bfg 255/75r17
There are people on here running 275/70-17's without any problems. This tire is slightly taller than the ones that you want. Hope this helps.
Zane
'07 Black Cherry 5AT, CQ, GY, UR, C8, 2Q, 37, C7, added Toyota ski rack attachments, passenger armrest, 2 rear door storage nets, K&N drop in filter, and a Cyclone air prefilter
Z'sFJ is offline
Old 06-19-2007, 02:38 PM   #3 (permalink)
barralf's Avatar
Thumbs up Re: Bfg 255/75r17
Thanks, I will check this weekend..
barralf is offline
Old 06-19-2007, 06:48 PM   #4 (permalink)
pnc_69's Avatar
Member Number: 11839
Re: Bfg 255/75r17
If you found BFG 275/70R17 MT tires let me know because I went to BFG website and I didn't see that size of tire.
pnc_69 is offline
Old 06-20-2007, 12:26 AM   #5 (permalink)
Z'sFJ's Avatar
Re: Bfg 255/75r17
I do believe that BFG makes that size just not in the M/T or the A/T that we would want. The only M/T that I know of in this size is the Goodyear MTR. Hope this clears things up.
Zane
Z'sFJ is offline
Old 06-20-2007, 05:53 AM   #6 (permalink)
barralf's Avatar
It is right; the only brand that has 275/70R17 is Goodyear: Wrangler AT/S ($184.00) and Wrangler MT/R ($218.00).
Yesterday I went to 4 Wheel Parts (Houston) and the guy recommended me the BFG 255/75R17. What do you think about those tires?
barralf is offline
Old 06-20-2007, 06:26 AM   #7 (permalink)
w5wi's Avatar
Member Number: 11734
Re: Bfg 255/75r17
barralf previously said: View Post
I replaced the OEM 265/75R17 with BFG TA/KO's of the same size with no problems. They work great. I have stock suspension.
There is another thread where a forum member says he's running BFG's that are 285/75R 17 with no rubs or lift kit.
Happy Trails!
TLCA #17625
LOS TRES AMIGOS IN MEXICO
TITANIUM METALLIC--A/T
ARB Bumper - Warn Winch - OME Heavy 886/895 - Bandi Mount - All-Pro Lower link skids - Bud Built skids - Snorkle - Toyota prefilter (cyclone air filter) - Optima Yellow Top Battery - Painless Dual Battery Control System - Scuba Driver Mod - Kenwood DNX 7120 GPS - A-TRAC mod - 110v add-on - Rock Rails - Rear Locker - Roof Rack - BFG TA/KO's - ARB Fridge/Freezer - '08 side visor mod - Royal Purple fluids - E3.68 Spark Plugs - All Pro Rear Bumper - All Pro Lower Links - M-Pac rear and side mounts
To be continued...
w5wi is offline
Old 06-20-2007, 07:43 AM   #8 (permalink)
Z'sFJ's Avatar
Re: Bfg 255/75r17
BFG does make two different 285/70-16's. One is 32.8 x 11.5 and the other is 32.7 x 11. Of course both are on 8.5 rims. The latter 'should' fit on the FJ without any problems since our rims are 7.5's. I have no experience with this. It is just my guess. The 32.7 is listed as a BSW just so you know the difference. As for the 255/75-17's I would take them. It is a BFG and an M/T. Ever so slightly taller than the stockers and you won't have any rubbing issues. I say go for it. Again, I hope this helps.
Zane
Z'sFJ is offline
Old 06-20-2007, 01:11 PM   #9 (permalink)
pnc_69's Avatar
Re: Bfg 255/75r17
Please let me know if the BFG 255/75R17 M/T fit perfect on the 17" stoke rims and with no rub with the body mount. Thanks
pnc_69 is offline
Old 06-21-2007, 12:33 AM   #10 (permalink)
Z'sFJ's Avatar
Re: Bfg 255/75r17
There shouldn't be any problems mounting that tire on the stock 17's. Also, I would seriously doubt that there would be any rubbing on the body mount. This tire, the 255/75R17, is slightly taller, maybe 3 tenths of an inch, and narrower, reportedly at just over 10 inches, than the stock 265/70R17. We are talking about a 32x10 versus a 31.7x10.6. The narrower the tire the less likely that it rubs the mount. Someone on here is running BFG's 255/85R16 without any problems. That is a true 33 inch tall tire. The width is the same as the the stock 265's. So, I hope this helps you out.
Zane
Z'sFJ is offline
