Old 10-11-2007, 02:02 PM   #11
Super Moderator
Fjamming's Avatar
Member Number: 6623
Re: Slight clearance issue
That is a tough call. If you could find a small spacer (1" or less) I would go for the spacer. Not to sure on how the caliper is constructed in that area but I am sure there is excess material that could be cut off. But you really are playing with fire. I am think you could at lest take it down to the same height as were the numbers are stamped in at with out any problems.
Josh, I'm quite sure even 1mm would make it clear (while caliper isn't hot). I have no idea how much they would expand when heated up.
Sandoo Blue FJ
SoCal Events Calendar
Fjamming is offline
Old 10-11-2007, 02:03 PM   #12
Super Moderator
Fjamming's Avatar
Member Number: 6623
FJ_Marine previously said: View Post
Alot of people are running spacers on their rigs that I know of. Check out Matt07FJ's rig. I dont think its hurting his articulation any.
I know Bandi and Mir207 had more rubbing issues with spacers installed. Mir207 had no choice but to use spacers. Bandi used them to widen the stance.
Sandoo Blue FJ
Fjamming is offline
Old 10-11-2007, 02:04 PM   #13
felonious's Avatar
Member Number: 12866
Here are the exact measurements on the rims that I put on and have a 1/2 inch between the caliper and the back of the rim.
Pro Comp Xtreme Alloy Series 7089
Part Number: PXA7089-7883
17x8, 6 on 5.5 Bolt Pattern; Backspace = 4.5 in.; Hub Centric = No; Max Load = 2200lbs; Offset = 0mm;
felonious is offline
Old 10-11-2007, 02:08 PM   #14
Super Moderator
Fjamming's Avatar
Member Number: 6623
11mm comes out to be about 0.43 inch
Sandoo Blue FJ
Fjamming is offline
Old 10-11-2007, 02:10 PM   #15
felonious's Avatar
When I got my rims they sent me three with the MM offset and one with 11 guess what happened it hit the caliper just the same as your changed out that one and everything is just fine the put it in the wrong box at the factory.
Old 10-11-2007, 02:19 PM   #16
Sean K.'s Avatar
Member Number: 9441
There are 5/16" wheel spacers available for most bolt patterns....not sure on the 6 on 5.5" bolt pattern, but I'd guess yes. Can't remember the brand.....C-P products maybe??
Sean
"I too pray for peace. Peace and justice. If we can't have both, I choose justice."-Defender
Sean K. is offline
Old 10-11-2007, 02:43 PM   #17
Super Moderator
Fjamming's Avatar
Member Number: 6623
Has anyone grind on the calipers? Do you think I'll have issues with the rears? I didn't get to test them. My neighbor helped me put the front one on, but I couldn't bother him to try and put the rears on too.
Sandoo Blue FJ
Fjamming is offline
Old 10-11-2007, 02:47 PM   #18
yoda's Avatar
Member Number: 2584
I was looking at those rims but decided to go with the Ultras because they had a 4 1/4 inch back spacing. I am close to the caliper with the 4 1/4 inch bs, had i gone with the 4 inch bs they would of rubbed. Your proplably only rubbing buy an 1/8 inch. I would use the smallest size spacer you can find, unless you want the wheels sticking out past the fender. With 33x11.5 tires and 4 1/4 bs my tire tread is almost dead even with the outside of the fender.
07 FJ, At ,Upgrade #2,Toytec 1/2 FR Spacer,Auto Vent Shades,285/75/R16 Dick Cepek FC-11's on 16x8 Ultra 50/51's
yoda is offline
Old 10-11-2007, 02:55 PM   #19
Super Moderator
Fjamming's Avatar
Member Number: 6623
yoda previously said: View Post
I'm rubbing by the thinest hair and that's why I was considering grinding. I truly think 1-2mm would've cleared. I have no idea what are the precautions regarding the minimal thickness of spacers. I would think that too thin and they might crack or warp.
Sandoo Blue FJ
Fjamming is offline
Old 10-11-2007, 03:01 PM   #20
WESBC's Avatar
Member Number: 6452
Send a message via AIM to WESBC
I think shadow-warrior grinded his calipers to fit his 16's. Try PM'ing him
Here's the link to his thread
He says he had some of the caliper grinded off in paragraph 3
WESBC is offline
