I've finally settled on the wheels for my FJ. They are Eagle Alloy Series 185. I had them converted to beadlocks. Finally had a chance to try them on the FJ today and found there's a clearance issue. The specs are:
16X8
6x5.5
4 backspace
-11mm offset
Upon installation, I find that the leading edge of the caliper just touches the wheel. It doesn't grind or catch, but it just touches. I can't put a index card between the caliper and the wheel. I've marked the portion of the caliper with red crayon. I apologize for poor quality in some of the pictures.
I knew it would be close when I ordered these, but I had no idea it'd THAT close. I didn't get to test the rears. So it looks like it's either wheel spacers or grind off a small portion of the caliper. If possible, I'd rather stay away from spacers. Can 2-3mm be safely grind off without compromising the caliper? I know they just touch right now, but I'm sure with the brakes heated up, there might be even more issues.
Your advice/opinion appreciated.
Sandoo Blue FJ
Walker Evans 2.5 dia. front shocks, adj. rear reservoir shocks, Pro Links. AP F&R bumpers, AP 1.25" UCA, Demello skid, TMax 9000 Competition winch. Viking Trail Line. 34X10.5X16 Swamper LTB. Trail Gear Sliders, Aeroflow, Lightforce Blitz 240 HID, All Pro Swing Out, .
Considering the importance of the brake system and the relatively unimportant consequences of a teeny tiny spacer, I would go with the spacer. Many folks have no problem with grinding on a brake caliper, but I find it to be a really dangerous idea. I don't know how small they make spacers, but a 1/4" would be plenty, I'm sure.
__________________ 1 Bored Clerk
Inchworm Gear E-Locker Guard
I agree about grinding on calipers, I have no idea how thick the steel is there and would'nt want to find out. As far as I know the spacer width will have to be at least the length of the wheel stud.
I have these wheels in 17x9 with 285/70s and no rubbing. Are you lifted?
This is a rubbing between the caliper and wheel, not tire and bodymount. Your wheels have different offset and backspace then my 16s.
1/4" would be nice. But I didn't think they make wheel spacer that thin.
That would be terrible. If my wheels would stick that far out, it's going to hurt articulation. I saw you edited the text and I echo your concern about not knowing the thickness of the steel in that red area. Was hoping some one has done this or know more of the calipers.
Sandoo Blue FJ
That is a tough call. If you could find a small spacer (1" or less) I would go for the spacer. Not to sure on how the caliper is constructed in that area but I am sure there is excess material that could be cut off. But you really are playing with fire. I am think you could at lest take it down to the same height as were the numbers are stamped in at with out any problems.
- Thomas Paine
