Anyone have a picture of the All Terrain Package wheel/tire combo that they can post? I've searched high and low and cannot find any pictures of this wheel.
happen to know why the spokes of the rim are designed that way? I just picked up my FJ and as i was examining the rims, trying to decide if i want to replace them. i noticed the spokes are sloped on one edge and not sloped on the other (take a close look at the above pic). Seems very odd to me but figured there must be some sort of explanation for why it was designed like that.
you mean the offset is 4.5" ? which if that's the case and they are 16x7 then that gives it a 12mm offset? just trying to figure out if I can go to 285/75/16 and 3" lift without rubbing issues. I know that's another horse that's been beaten to death. Darrick from ToyTec is saying that 4.5-5" backspacing with 3" lift will not have rubbing issues. starting to get more confsed the more i try to read up and educate myself on the subject
That is the tire size and wheels I run on my '08 Off Road FJ. No rubbing. If you do experience rubbing, a body chop will take care of it. Search for "body chop" and you will see what I mean! :cheers:
thanks for the advice. i've read up on the body mount chop already and will have a cutting wheel and welder on standby once i put everything on. i see you run a 3" spacer so that helps with no rub i guess. how is the clearance on the inside against the UCA's and other suspension components? backspacing is no issue?
put on the cooper discoverer stt tires and there was no rub before the lift even went on. didn't get a chance to try under any flex. but on flat road it turned side to side no problem. put the lift on 2 hours later and still no rub. got it all muddy in the woods and had not issues. thought i'd update
Related Threads
Toyota FJ Cruiser Forum
3.7M posts
122.6K members
Since 2005
