Old 10-23-2007, 07:42 AM   #1 (permalink)
rutherk1's Avatar
Member Number: 3982
Send a message via Yahoo to rutherk1
Steelies lugs
Greetings.
I just put OEM steelies on my truck. Can someone verify which lug nuts I need.
12mm x 1.5? Is that all I need to tell the autoparts store?
The alloy nuts fit and seem to be safe but they stick out and the washers obviously rattle when I shut the door.
Thanks!
FJ's = possessive
FJs = plural
rutherk1 is offline
Old 10-23-2007, 08:16 AM   #2 (permalink)
1911's Avatar
Member Number: 4994
Re: Steelies lugs
DO NOT use the flat washer lug nuts from your alloy wheels, they are NOT safe. You need lug nuts with a tapered seat for your steel wheels. 12mm x1.5 is the right thread pitch though.
KE5VTE
TLCA # 16550
All men dream: but not equally. Those who dream by night in the dusty recesses of their minds wake in the day to find that it was vanity: but the dreamers of the day are dangerous men, for they may act their dreams with open eyes, to make it possible - T. E. Lawrence
1911 is online now
Old 10-23-2007, 08:31 AM   #3 (permalink)
rutherk1's Avatar
Member Number: 3982
Re: Steelies lugs
Are we sure its 12mm x1.5? I saw one the forum 12mm x 2.0 as well.
Just making sure. Looks like I will be making a trip to Napa at lunch.
Thanks!
FJ's = possessive
FJs = plural
rutherk1 is offline
Old 10-23-2007, 08:53 PM   #4 (permalink)
1911's Avatar
Member Number: 4994
Re: Steelies lugs
rutherk1 previously said: View Post
Thanks!
Yeah, I guarantee they are 12mm x 1.5.
KE5VTE
TLCA # 16550
1911 is online now
Old 10-24-2007, 07:32 AM   #5 (permalink)
rutherk1's Avatar
Member Number: 3982
Re: Steelies lugs
1911 previously said: View Post
Cool. A stop at Napa got me going. I got a bunch of those acorn style open ended wheel nuts. The threads stick out the back. Looks pretty industrial with the steelies on there. They are heat tempered too. When pulling these other ones off they look like they have an external aluminum shell that bends easily. I didnt know car companies still did that... Weak.
Thanks for the help.
FJ's = possessive
FJs = plural
rutherk1 is offline
Old 10-24-2007, 02:48 PM   #6 (permalink)
zelig2's Avatar
Member Number: 8990
Re: Steelies lugs
Give CruiserLarry a call and pick up some Gorilla locking lugs. They look better and help secure the wheels.
2007 Black Diamond 4x4 AT w/ CQ DL & GY
mods finished:
Gobi Stealth Roof Rack, BFG AT KO 265/70R17, ExpeditionOne Sliders, Pioneer AVIC-D3, Gorilla Locking Lugs, ScanGaugeII, aFe CAI, ExpeditionOne Bullbar Front Bumper
mods planned:
Superwinch epi9000, All-Pro W/E Front Coilovers, Dual Battery Kit
zelig2 is offline
Old 10-25-2007, 07:09 AM   #7 (permalink)
rutherk1's Avatar
Member Number: 3982
Re: Steelies lugs
zelig2 previously said: View Post
Cool. I was looking at the Gorillas. Which ones do I need? I am going to order them from summut because they are close by.
I dont want them to be colored (silver is fine) I know I need 12mmx1.5 but which ones specifically do I need from Gorilla?
Thanks!
FJ's = possessive
FJs = plural
rutherk1 is offline
Old 10-25-2007, 07:41 AM   #8 (permalink)
Member Number: 14683
Re: Steelies lugs
Never run the factory lugs - meant for Toyota aluminum wheels - on steel rims. If you look closely at the steel rim, the bolt holes have a conical depression.
The Toyota lugnuts do NOT fit and WILL loosen up. You need an old fashioned conical-seat lugnut to ensure proper torque, and that the lugnut won't loosen up.
I got steel "universal fit" wheels with studded winter tires for my Prius, and aftermarket steel wheels with Toyo Open Country G-02 Plus studless winter tires, for my FJ. I was quite surprised that both vehicles use the same lugnut.
I got my lugnuts from NAPA here, according to the box they are:
M12-1.5 x 21mm
Part number #641-2042
For driving in winter, with road salt, the best way I have found to keep the steel rims from rusting is to spray a product like Fluid Film on the back and front side, before mounting.
I highly recommend the Toyo Open Country G-02 Plus as a winter tire. I only had mine on 2 weeks before Spring arrived, but on icy roads they really do work as advertised, without the studded tire noise.
jayman is offline
Old 10-25-2007, 07:49 AM   #9 (permalink)
Manhattan's Avatar
Member Number: 7697
Re: Steelies lugs
And don't trust the dealership service department for advice on this topic. My FJ came with steel wheels - I brought the alloy wheels AND the correct lugs for the alloy wheels to the dealership for them to do the swap. They reused the lugs from the steel wheels.
Later, I told the service manager about this. His response: "How could it make a difference? They're both Toyota lug nuts". I had to teach him (based on info garnered from this site) how Toyota mounts an alloy wheel vs. a steel wheel. I went to Butler tire after that.
6-Speed, 883s, 33s on Body-matched Steelies, Demello Bumper, M8000, TG Sliders, AllPro Skid, AllPro High-Clearance Tailpipe, D3
www.800degrees.com
Manhattan is offline
Old 10-25-2007, 07:51 AM   #10 (permalink)
rutherk1's Avatar
Member Number: 3982
Re: Steelies lugs
Manhattan previously said: View Post
Why would you take your truck to the dealership
I think I am going to get these
Gorilla Lug Nuts: GOR-41137 - summitracing.com
I have noticed there are 2 kinds of conical lug nuts in this size. Some have a taper and at the botton right before the conical part and some dont.
FJ's = possessive
FJs = plural
rutherk1 is offline
