I've been running 285's for almost a year now with no issues. They were mounted on the 16x7 OEM steelies off a Tundra. Now I have them mounted on 16x9 Axis Regulators. I love the wheels and they make my truck look waaaaay better but now I rub at full lock. Is this due to the extra width of the rim? That seems like the only reasonable explanation. Looks like I'm gonna have to visit the local shop to chop those body mounts.
hey man long time no talk, good choice on the regulators, im looking at those too, where did you get those, ive been looking for them, did you get them someplace local, and definitely get those body mounts chopped, just in case is always better
Voodoo Blue 4x4 AT QC UR C7 V5 Z2
Mickey Thompson 265/70/17 Baja MTZ's, Moto Metal MO957 17" -12mm offset, Demello Sliders, Blue RockBlockers, Painted front bezel, PIAA Extreme white bulbs, billet short stubby 9 inch antenna, AVS In Channel Vent Visors, OME 884 front coils with 5mm Toytec spacer, Raptor Muffler with dump before axle, Toytec custom stock ride rear coils, OME front and rear nitro shocks
and the mods keep coming....and my wallet keeps crying..
The extra width of the rim will set the tire slightly more outboard, therefore making it more likely to rub the body mount(s) when the wheels are turned. A slightly different backspacing on your new wheels might put them out there as well.
Good insight as always.
Now go chop 'em! (If you can do it yourself, I found it to be pretty fun. How many people take grinders and welders to their new(ish) vehicle? I did! )
__________________ WANT MORE FROM YOUR FJ? Click one of the links below!
Just do a body mount chop and you will be fine.. I have a 3" lift w/33.12.50 on 18" rims. My off set is -12 and I don't rub at all. EVER. Doing a chop is the way to go. It is a very passive thing to do and will not void any warranties. I recommend it highly. Good luck bro..
^^that, and...
looks like your wheel comes in two offsets.
-10mm offset, like a 1" spacer on your last set up.
-24mm offset, like a 1.5" spacer to your last set up,
assuming your Tundra steelies were +15mm offset
good looking wheel
like everyone else said, body mount chop and your good
'07 FJC Ti silver 4x2 on steelies, spidertrax spacers and 4x4 springs
'91 240sx (modded to hell and back drift whore)
