Old 11-20-2007, 03:19 PM   #1 (permalink)
Member Number: 15130
Thumbs down Tire Size - Once and For All (Please?)
Greetings again all of you FJ Lovers... I've read more of this forum than I care to explain and I have yet to see a single thread that answers this question:
What is the maximum size of a tire that you can put on a stock FJ Cruiser with no lift and the stock 17 inch rims?
I am in the market for new tires and I was told by Rough Country that I should check out the Mickey Thompson Tires tires. I like the way they look, they sound solid, anyone have any experience?
Thanks well in advance!!
greybrimstone is offline
Old 11-20-2007, 06:35 PM   #2 (permalink)
Itanius's Avatar
Member Number: 15370
Re: Tire Size - Once and For All (Please?)
From what I've gathered, the size you're looking for is 285/70-17.
I could be wrong, and if so, would be interested to know.
.........-Travis-
'08 Black Diamond]
Itanius is offline
Old 11-20-2007, 06:43 PM   #3 (permalink)
Fjamming's Avatar
Member Number: 6623
If you're going to flex the suspension, 285 will rub. If you're not going to flex, you might be able to put 35? I imagine 35s won't rub if you don't move it.
For the most part, Ive read that 275 (GY MT/R) will fit stock and have no issues. I'm positive that not all 285s will fit without rubbing when flexed.
Sandoo Blue FJ
SoCal Events Calendar
Fjamming is offline
Old 11-20-2007, 07:16 PM   #4 (permalink)
Voodoogirl's Avatar
Member Number: 1808
You've read a lot because every tire is different. Tires of the same size will all measure out different. It's that 1/8 inch here, or 1/4 inch there that makes the difference. It might say 285/70-17 but there are minor differences. Then add in factors like H/T, or A/T, or M/T with different tread patterns, some of which wrap around the sidewall, (making the tire slightly wider), and that's why there isn't a clear answer.
I'm sure there are slight differences in every FJ too, and the suspension will settle. My tires didn't rub at first, but after about three weeks, they did. If you're worried, then stick with the stock size, or just do a 275, but you'll be limited in which tires you can get in that size.
K
'07 FJ Voodoo Blue,
Toyo 295/70-17 M/T's
ToyTec custom lift
Expedition One bumper and sliders
...and, some Moab dirt
'69 3/4t Camper Special Chevy
Orange w/white roof
'05 V-Star 650 Custom, Blue w/blue flames and lots of chrome
TLCA #16191
Voodoogirl is offline
Old 11-21-2007, 10:28 PM   #5 (permalink)
L8Apex's Avatar
Member Number: 2080
275/70/R17 is the max that will fit reliably with no rubbing under any conditions.
285/70/R17 might fit depending on the tire. But most tires of this size rub the body mount when turned full lock and little suspension flex.
The Tank (aka "RED PILL") : 2007 FJ Cruiser, 4x4AT, black cherry
- Expedition One bullbar bumper
- Expedition One rock sliders
- BudBuilt skids (front, mid, TC, crossmember)
- Bilstein 5100 front struts, set at 1.75" lift
- GoodYear Wrangler Silent Armor tires 275/70/R17
The Fighter Jet: 2001 MR2 Spyder, silver
- 2ZZ motor/6spd swap
- TRD Sportivo suspension
- 3.0 Racing chassis bracing
- JDM Toyota hardtop, soft-top delete
L8Apex is offline
Old 11-21-2007, 10:42 PM   #6 (permalink)
fj4x4's Avatar
Member Number: 13646
L8Apex previously said: View Post
Absolutely agree, and that's what I've heard over and over. I bought 275's and there's no rub.
fj4x4 is offline
Old 01-22-2008, 05:53 PM   #7 (permalink)
Member Number: 11364
I have had some clients get into the 285 series with all terrain and reported no problems ... BF G's Rugged Trail's
mason@tirerack.com is offline
Old 01-22-2008, 06:14 PM   #8 (permalink)
tibaal89's Avatar
Member Number: 8825
Send a message via AIM to tibaal89
This is absolutely true. I believe 275/70/17 is an excellent size for stock, no lift FJ's.
No rubbing, great tire.
I don't have one of the front, but here's a pic of the rear under max flex... just fits!
-Mike (KE7ULD)
Check out my blog thing!
Something there is that doesn't love a wall, that wants it down...
AZFJ.org - Arizona FJ Cruisers!!
tibaal89 is offline
Old 01-23-2008, 07:18 PM   #9 (permalink)
Sky
Sky's Avatar
Member Number: 10796
Lesson 1: There is no thing as "once and for all" on this forum.
Sky is offline
Old 01-23-2008, 08:40 PM   #10 (permalink)
SwiCago's Avatar
Member Number: 15488
leave the stock dumlops on there and you shouldn't have a problem
Cheers
AL
SwiCago is offline
