Old 12-02-2007, 08:35 PM   #1 (permalink)
pdrmant's Avatar
Member Number: 52
Screw in the side-wall (ish), what to do?
Had a slow leak (2 to 3 lbs. of pressure) on my passenger rear so I took it to the Sears Auto Center. They said it was irreparable and showed me why. The screw is on the inner part of the tire and about 3/4 of an inch in and all the way down to the tread.
My spare is fine, but it has never been put into the rotation. The tires are worn about halfway down, so buying a new one seems weird because of my current wear.
Any suggestions? Should I just leave it in and air up 2 to 3 lbs. everyday?
Will getting a new tire cause the others to wear funny or whack out the alignment?
They are General Grabber AT2s (very similar to the BFG ATs in tread pattern and height).
Danke.
_______
/_|o[____]o
[1---L-O( fj )O-
()_)()_)=°°=)_)
pdrmant is offline
Old 12-02-2007, 08:53 PM   #2 (permalink)
ChrisH's Avatar
Member Number: 10374
Re: Screw in the side-wall (ish), what to do?
Put a plug in it yourself. It takes just a few minutes.
What is the worst that happens - it leaks again.
ChrisH is offline
Old 12-02-2007, 09:03 PM   #3 (permalink)
cruiserlarry's Avatar
Member Number: 2011
ChrisH previously said: View Post
Not quite correct. The worst that can happen is a blow out while driving at higher speed while turning - which could cause a serious accident. That is why no professional tire shop will repair a side wall or tread corner puncture.
(and most states will hold that shop liable for making such a repair).
If you plug that hole, and the tire heats up enough from driving at speed or windy roads, the plug could blow out - and if the tread corner / sideway is being pulled under on a turn, could cause the tire to rupture / blow much faster than a "leak" - obviously creating a dangerous situation.
I know, lots of folks have done it successfully, blah, blah, but I just wanted to present the true "worst case senario" - and why the shop declined to help you...
TLCA #9632
cruiserlarry is offline
Old 12-02-2007, 09:43 PM   #4 (permalink)
pdrmant's Avatar
Member Number: 52
Yeah, I figured it to be a bad bad. I was looking for ideas on next steps and the like.
_______
/_|o[____]o
[1---L-O( fj )O-
()_)()_)=°°=)_)
pdrmant is offline
Old 12-02-2007, 10:26 PM   #5 (permalink)
targa88's Avatar
Member Number: 11127
Send a message via Skype™ to targa88
Side wall damage = new tire.
Can not be securely repaired
targa88 is offline
Old 12-02-2007, 11:54 PM   #6 (permalink)
Member Number: 8654
get 2 new tires..
eviioiive is offline
Old 12-03-2007, 12:03 AM   #7 (permalink)
AceTechno's Avatar
Member Number: 4098
Use a can of Fix-a-flat. It will plug it up for a small puncture wound to the tire. Leave the screw in or pull it out to see what happens. Might buy you some time in not having to buy new skins. Just an idea.
PERFORMANCE: Airaid intake, Gibson Exhaust, Royal Purple Oils
LIFT KIT: Toytec/Donahoe Racing 3", Spidertrax spacers
EXTERIOR: Rear Tail lite Guards, GoodYear MT tires, AP Sliders, PIAA Headlights/dome lites, Fourtrex, Hi-lift
COLOR: Voodoo Blue 4x2
AUDIO: Dice iPod interface
INTERIOR: ScanGuage II, Ellis Design Black Handles & Battery Clamp. Littlelite 12" map light W/ Dimmer.
My Build: http://www.fjcruiserforums.com/forum...shockwave.html
AceTechno is online now
Old 12-03-2007, 04:37 AM   #8 (permalink)
AZFJCRUZ'er's Avatar
Member Number: 11220
Change it out. Your life is worth more than a tire or even a new set.
4X4 Auto, KC Daylighters, Brush Guard, Daystar Level lift, Helo Wheels wrapped in Goodyear Silent Armor 275-70/17 tires, Nerf Bars, Tail light Guards, Billet Grille
www.myspace.com/kavliaris
Live life and take risks......a life lived in fear is wasted.
Fart on a friend, it'll make you laugh!
AZFJCRUZ'er is offline
Old 12-03-2007, 06:39 AM   #9 (permalink)
Bang Bang's Avatar
Member Number: 3795
My .02....buy 1 new tire. Put the new tire and the spare on the rear and move the good/worn tire that is currently on the rear to the spare. Then rotate as you normally would. Like others have said, your life is not worth the cost of 1 tire.
Mike
Where do you park your ride? Check this out...GarageFreaks.com
Acquired 07/03/06 2WD SUN FUSION
Member of the Hurricane Cruisers and damn proud of it!!
Thanks to Nate and Randy for their fine craftsmanship!!
Bang Bang is offline
Old 12-03-2007, 07:55 AM   #10 (permalink)
pdrmant's Avatar
Member Number: 52
Bang Bang previously said: View Post
This was my thought this morning on the way to work.
I will buy a new tire, and put the current spare into the mix.
Then I will fix-a-flat the screwy one and use it as the spare until I can afford 3 new tires to complete the set.
Thanks for the responses.
It's kind of a sad feeling when your ATs have wear from the asphalt. Might have to go with some Terra Grapplers next full set. The Generals perform really well and look great, and the price is great, too ($80.00 per on Tire Rack). I think they must be a little softer than the BFGs they are modeled after.
Thanks again...
_______
/_|o[____]o
[1---L-O( fj )O-
()_)()_)=°°=)_)
pdrmant is offline
