Painted headlight bezel, Series 87 steelies with 255/85-16 Maxxis Bighorns, BMC, ARB full length rack, 60" hi-lift, OME Heavies on all 4 corners, Budbuilts front to back, OEM sliders, Scuba Driver mods, Upper and Lower rear Digger Links, TRD CAI, All-Pro High Clearance tailpipe, Custom Built Rear Shelf, Hacked Rear Diff Lock, VSC on-off switch, Custom Expedition One Front Bumper, EPi 9000lb winch with synthetic line, and lots of manual recovery gear and tools.
Tony, those tires look great on your rig. Its still a surprise to me that I have not seen you driving around, considering that I am in Pomona Monday-Friday for school. Now that your tires are on, I still may not see you, but I'm sure I will be able to hear you if you are near.
+1 on the LTBs, I had a set and was unstoppable off road. Just don't go below 16 PSI on a 8" rim with no beadlocks. I had one bead unseat in the worse possible place, took us and hour to pull the truck out and swap the tire.
As you have stated they are not real good on the street. With my long trips to CO and other parts of Texas, I had to change...it was too much vibration above 60 MPH even with balancing and Dynabeads. Make sure you run them at 40 PSI or so to keep the side lugs off the ground, should be able to just barely slip a business card under there, this will smooth it out a lot.I opted for the Super Swampers SSRs in 285/75 R-16 (33.6 diameter) and since they are a radial, it is much smoother. Not bagging on your setup, Swampers rock!
Vice President of TTR
1972 Freeborn Red FJ40 4x4
I love the sound of my LTB's! It means I'm getting ready to hit the dirt soon.
x2 on running them at 40-42psi on the street, otherwise you'll wind up tearing lugs off of the sidewall edge when you turn.
[Edit] Plus no body mount rub with stock wheels because of the narrow width!
I took mine to three different places before they finally got balanced. Kauffman was the ticket. The dealership wouldn't touch them and 4WP had a tough time even though they mounted them (bought them from 4WP). Now they are great up to about 70mph where they start vibrating in unison and you get that weird sensation between your ears , then it smoothes out again at 75mph.
__________________ Rick C ~ ~ I aim to misbehave. 2007 GSJ15//Ti Ag//4WD AT All-Pro bumper, IFS skid, Extreme LCA links, LCA skids & Bandi mount Bud Built trans skid/crossmember/gas skid Metal-Tech step sliders OME 886/895 Total Chaos UCAs & spindle gussets Super Swamper 34" LTBs Warn 9.5xp/synth Demello rear bumper ACC Toyota Custom Tube Fenders Where Do You Want to Take Your Truck?
Upstate Cruisers - Events Officer
GA Cruisers, Olde North State Cruisers - supporting member
TLCA #16667
