Fjamming previously said:
Here you go.
Thank you very much .... Thats exactly what I needed !!
jtmroczk previously said:
the extra 0.75" of wheel width per side will make the tire's side wall look a little more on the square side.
OEM ET of +15 to ET-12 pushes the the whole wheel/tire out 27mm ~ 1 inch
your off the UCA but now the radius of the arc your tire moves on is longer by 27mm, so your probably into the body mount somewhere near full lock if you haven't cut it out of the way already.
hope that helps
I'm sure somebody on here has that size wheel/tire combination and can say from experience though.
Thanks ...... And yeah , I've had my bodymount chopped already ,,,,,,,,,
FJinFredericksburg previously said:
Same as my 955's in offset and width, I still clear everything using 35's
Good to know ....... and nice rig btw..........
