265/70/17 with pressures around 35psi and 8k miles
Recently I have noticed my front driver side tire is making a rapping noise whose frequency increases and decreases with my speed.
The other tires do not seem to have this noise. There are no rocks or other abnormalities with the tires. It does sound rubbery not like metal or grinding. It is like the normal tire noises but much more pronounced.
There is still a good amount of tread on all of the tires, and all of the tires have similar tread.
need to rebalance that tire. Ive done it on mine at 5k miles due to wear and chunking from the lugs. do you notice your steering wheel shaking a little too?
__________________ Ligten up, it's the internet!
air previously said:
Quote from: BigDouggieDoug
I have the same problem with my terra grapplers. Was worried there might be something off with the suspension, but no steering wheel shake or anything odd otherwise, just a noise. It's really noticeable under 20mph.
Yup mine also disappears at higher speeds, I am not sure if it actually disappears or just is drowned out by the normal tire noise that gets louder as I go faster.
Took it to a tire shop, where the guy said the noise was probably being caused by a warped/bent belt in the tire, and that it was probably dangerous.
He also said it probably wasnt a balance issue.
He could not check it out because one of his machines was broken, but if I would come back next week, he would check the tire and be happy to sell me a new set if they turned out bad.
