Old 02-04-2008, 08:36 AM   #1 (permalink)
HeliArcTech's Avatar
Member Number: 17186
Spidertrax Wheel Spacers
what does every body think about using these, good bad or indifferent, will they help me fit 285/70/17 tires under a stock height ride with no rub? or will they allow me to not chop anything after lift? :
Spidertrax Wheel spacers 1 1/4" thick
Hub Centric (Late Model)
These 1.25" 6 on 5.5" 6061T6 aluminum spacers are an easy way of spacing out front and rear late model Toyota axles that run hub centric wheels (lug nut seating surface is square as apposed to conical). Each kit comes with 2 wheel spacers, 12 metric M12x1.5 wheel studs (pre-installed), 12 M12x1.5 lugnuts, and Loctite. The wheel spacers are anodized in dark blue, which is a double anodizing process for twice the corrosion resistance. In addition, each wheel spacer is both wheel & hub centric for a perfect OEM fit. Proudly manufactured in the United States of America.
Spidertrax Wheel Spacer Kit
• Fits the following vehicles:
- 1980-Up 4 Runner (w/o Locking Hubs)
- 1995-Up Tacoma 4WD (w/o Locking Hubs)
- 2000-2006 Tundra
- 1993-1998 T100 (w/o Locking Hubs)
- 2007-Up FJ Cruiser
• 6 on 5-1/2"
• 1-1/4" Thick
• Part #: WHS-007
Price: $99.95
HeliArcTech is offline
Old 02-04-2008, 08:59 AM   #2 (permalink)
tisilverFJ's Avatar
Member Number: 1394
Re: Spidertrax Wheel Spacers
Search "spacer" or "Spidertrax". There are a lot of threads on this.
Just a few to help.
Daystar 2.5" Front & 1.5" Rear Lift Photos
Spider Trax wheel spacers installed!
Wheel Spacers
TLCA#16292
Toytec custom coil lift,SS brake lines. PM me for Discountshttp://www.toyteclifts.com/fjcruiser...ruiserliftkits
All Phase Offroad diff skid,engine skid,Hi-Lift mount,axe/shovel mount,HD LCA frame mounts.
Spidertrax spacers.
All-Pro HD LCA's,Bandi mount.
FabFours front bumper w/PIAA lights
Stock Toyota steel wheels with 35" MTZ's.Gas/water cans mounted to stock rack. Midland hand-held CB. Thule fairing. OEM rock rails. A-Trac/Locker hack.
tisilverFJ is offline
Old 02-04-2008, 10:08 AM   #3 (permalink)
bandi's Avatar
Member Number: 2261
Wheel spacers will only help you to clear the
brake calipers with some 16" rims, and give
you a wider track width, it will not help you
fit bigger tires, but in fact, cause more of
a rub, and the need for the body mount chop...
The "Bandi Mount" Now By ALL-PRO OFF-ROAD
Phone:951-658-7077-Fax:951-658-2375-Email
bandi is offline
Old 02-04-2008, 10:11 AM   #4 (permalink)
FJVP's Avatar
Member Number: 8952
I ordered these to get my "stance" a bit wider after I put the lift on. I went this route so I did not need to change wheels since they are fairly new.
Tim
FJVP is offline
Old 02-04-2008, 10:21 AM   #5 (permalink)
ok so i think im gonna get them just for the wider stance factor, im not redy to lift or get new rims and rubber yet any ways .
They wont make a stock rig rub will they??
Old 02-04-2008, 10:29 AM   #6 (permalink)
SwiCago's Avatar
Member Number: 15488
Not sure if they help against rub, but I installed mine for my 16's ... Nice wide stance.
16x8s-installed-spidertrax-finally
Cheers
AL
SwiCago is offline
Old 02-04-2008, 10:34 AM   #7 (permalink)
FJVP's Avatar
Member Number: 8952
HeliArcTech previously said: View Post
They should'nt. I'm running 265/70/17 tires on 8.5" wheels with 4.5" backspacing and -6mm offest. Adding the spacers will give me +25 or about 1" more width. I will post more when I get them put on.
Tim
FJVP is offline
Old 02-04-2008, 09:17 PM   #8 (permalink)
superfly's Avatar
Member Number: 11876
Any info on failure of the spacers? That's the only thing that spooks me about these things.
VooDoo Blue: upgrade package 2, Ram Brush Guard, Trail Gear Sliders, K&N Filter, Daystar Leveling kit, IPF Fog Lights.
superfly is offline
Old 02-05-2008, 09:27 AM   #9 (permalink)
bandi's Avatar
Member Number: 2261
Been running my spidertrax's for 1 1/2 years
now, not one problem at all, never even came
loose... I believe Mir007 has ran these HARD
on his rig with zero issues also, along with all
the others here on the forum... They are really
considered Hub Adapters/Extensions, not
spacers...
Spacers are bad, since they leave you with less
threads for you lugs...
bandi is offline
Old 02-05-2008, 09:42 AM   #10 (permalink)
MIKESCRUISER's Avatar
Member Number: 16266
SwiCago previously said: View Post
wow what a big difference. looks good.
MIKESCRUISER is offline
