Old 02-06-2008, 11:38 AM   #1 (permalink)
makim's Avatar
Member Number: 16254
what the heck is "hub centric"
I wanna buy pro comps 7089 but there are two types,
can someone definativelly tell me if I need hub centric or not and what that is?>
pete
PXA-7089-7838 Free Ground Shipping!
Pro Comp Xtreme Alloy Series Black 7089 17x8 - 6x5.5 - Hub Centric - 4.5 BS $156.00
PXA-7089-7883 Free Ground Shipping!
Pro Comp Xtreme Alloy Series Black 7089 17x8 - 6x5.5 - 4.5 BS
makim is offline
Old 02-06-2008, 12:22 PM   #2 (permalink)
SwiCago's Avatar
Member Number: 15488
Re: what the heck is "hub centric"
Can tell you what you need, but I'd recommend the hub centric ones.....
HUB CENTRIC
Definition: A wheel that is centered or located on the hub by a machined center hole-as opposed to "lug centered" wheels that are located by the position of the lug nuts alone.
Cheers
AL
SwiCago is offline
Old 02-06-2008, 12:24 PM   #3 (permalink)
breauxtus's Avatar
Member Number: 10906
I'm sure I'll be corrected if I'm wrong, but hub centric refers to either a wheel or a wheel spacer that doesn't just bolt onto the vehicle, but is precision machined to match exactly the OEM hub flange. This nearly eliminates wheel shake as a result of poor lug tightening, poor machining, etc. It also keeps the wheel/wheel spacer as close to OEM as possible, relegating you to look for poorly balanced wheels as any cause for steering wheel shake/shimmy.
Anyone else, please chime in and correct my response or add to it.
Mike
YinYang
2007 FJC
They call me The Nukldragr!
breauxtus is offline
Old 02-06-2008, 12:52 PM   #4 (permalink)
Thermal_Scorpion's Avatar
Member Number: 8817
I was told when I bought my rims that the FJ needed hub centric versions.
"Trailstalker," 07 TitMet, AT, Opt 1, Garmin 60CSX, PIAA Extremes, Aeroflo Light Shields, Rear Gate Axe Mount, Trail Gear Rocksliders, All-Pro IFS Skid and Transmission Skid, BFG KM2 285/70/17, Scan Gauge II, Black KC Slimlite Fogs, Black KC Slimlite Driving Lights, PIAA 510 XT SMR, Fourtreks Hi-Lift and Dual Tool Mounts, Midland 75-822 CB, Bandi Mount with Firestick Anetnna, AR Vice Rims, aFe CAI, OME Medium Lift, SCUBA Driver Mod, Road Armor Bullbar Bumper with Warn 9.5Xp, Decepticon Emblems.
Thermal_Scorpion is offline
Old 02-06-2008, 12:56 PM   #5 (permalink)
4XX4's Avatar
Member Number: 9918
breauxtus previously said: View Post
Mike
That's a great explanation. kudos.
Blacksand Beast.
El Toro Rojo
http://www.fjcruiserforums.com/forum...toro-rojo.html
FJC Club ( Creepin' n Climbin')
Aloha FJ Cruisers (Wheelin' in paradise)
SoCal FJ Cruisers tag-a-long
4XX4 is offline
Old 02-06-2008, 03:27 PM   #6 (permalink)
makim's Avatar
Thermal_Scorpion previously said: View Post
I was told no to hub centric for fj cruiser
PXA-7089-7883
source Mike from offroadstore.com
makim is offline
Old 02-06-2008, 03:56 PM   #7 (permalink)
abophx's Avatar
Member Number: 3960
Mike
The FJ hub does have a flange that the wheel would have to fit over, if this is relative to the question..
YOUR PERSONAL FUKIN RAY OF SUNSHINE
Blue MT6
abophx is offline
Old 02-06-2008, 04:45 PM   #8 (permalink)
Woodsman's Avatar
Member Number: 3643
I think you would have to consider hub-centric to be ideal . . . but certainly not required. I like the positive location the hub provides rather than the "where's Waldo" locating method of the lug nuts.
2008 Sandstorm, AR Teflon Chamber, Nitto Terra Grappler 285/70/17, OME/Toytec lift, BudBuilts, MPAC, Exp One w/Superwinch 9000s, Viair 450, Dual batteries, AllPro lower links
Visit the Woodsman http://www.fjcruiserforums.com/galle...m/IMG_0854.JPG
I am the Woodsman, the four-wheelin', tree-farmin', custom-furniture-makin' son-of-a-b:tch descendant of Olaf "The Woodcutter" Ingjaldsson.
Woodsman is online now
Old 02-06-2008, 04:57 PM   #9 (permalink)
makim's Avatar
"Mike Nevitt - OffroadToyStore.com" <mnevitt@offroadtoystore.com> wrote:
Definitely not hub centric. I don’t know how this rumor got out there, but people seem to always ask. The FJ cruiser has caliper clearance issues, but not on a 17”.
Thanks,
Mike Nevitt"
Im gonna trust this guy
makim is offline
Old 02-07-2008, 06:42 PM   #10 (permalink)
Member Number: 11364
Most wheels that are universal and fit a variety of vehicle will need a center ring (or shim) to match exact to the hub of the FJ. If relying of the lugs (or lug centric) to keep the wheel tight to the hub is not recommended. If a lug backs off or a stud is broken will cause severe vibration and possible wheel failure. In my opinion, the wheel should be a hub centric fit it insure your safety. Feel free to contact me at 800-428-8355 x: 692 if you have additional questions.
- Mason
mason@tirerack.com is offline
