Mickey Thompson 33x12.50x17 & Xd Series 17x9 Fitting???... - Toyota FJ Cruiser Forum
post #1 of 20 (permalink) Old 02-14-2008, 05:32 PM Thread Starter
FreshChip119's Avatar
Quoted: 25 Post(s)
Question Mickey Thompson 33x12.50x17 & Xd Series 17x9 Fitting???...
Baja Radial MTZ, 33x12.50R17LT
Part #: M/T5273
Outlined White Letters
Load Range = D
Max Load = 2600
Tread Depth = 20.5/32
3-Ply Sidewall
Overall Diameter = 32.8
KMC XD766 SERIES DIESEL BLACK 17X9 6 ON 5.5 BACKSPACE = 5" OFFSET =0MM
WILL THIS TIRE AND WHEEL FIT MY FJC...
I HAVE A 3" TOYTEC LIFT...
WILL IT RUB MY BODY MOUNTS?...MY UCA?...
07 Toyota FJC
Voodoo Blue
4x4
"Modified"
FreshChip119 is offline
post #2 of 20 (permalink) Old 02-14-2008, 07:33 PM Thread Starter
Quoted: 25 Post(s)
Re: Mickey Thompson 33x12.50x17 & Xd Series 17x9 Fitting???...
Anybody Got An Opinion...
07 Toyota FJC
Voodoo Blue
4x4
"Modified"
post #3 of 20 (permalink) Old 02-14-2008, 07:49 PM
Quoted: 0 Post(s)
I think you will have to use wheel spacers and do the body mount chop...my 2 cents.
Current Mods:
() Fabtech 6" lift
() Moto Metal 951b wheels
() BFG MT 35x12.5x17
() Bushwacker Pocket Flairs
() Smittybuilt M1 Front Fender
() Smittybuilt 9500 Winch
.... much more stuff
buddoggin is offline
post #4 of 20 (permalink) Old 02-14-2008, 08:20 PM
Castille's Avatar
Quoted: 0 Post(s)
I run 33x12.5 Nitto Terra Grapplers on a nine-inch wide rim. I also have a ToyTec 3" lift. Obviously, this is not an identical setup, but it may be instructive to your application. My setback is -6mm.
With -6mm setback, I have exactly 15mm of space between the sidewall and the UCA. It does not appear to have ever rubbed.
So, if my wheels had zero setback (like the KMC's) instead of -6mm, the tire would be 6mm closer to the UCA. To wit: fifteen millimeters of room, minus six millimeters, equals nine millimeters. That's just 3/8 of an inch of room to spare (a.k.a. less than one centimeter) with the MT's and KMC's.
That's probably too close a fit.
And yes, you will need a body mount chop.
Castille is offline
post #5 of 20 (permalink) Old 02-14-2008, 08:37 PM
FJ FunJunkie's Avatar
Quoted: 1 Post(s)
I'm running those on stock rims without a chop or spacer with no problem even before lift it was just minor rub. Not sure about them on different rims, they change the shape of the tire depending on the width.
http://www.fjcruiserforums.com/forums/signaturepics/sigpic7470_2.gif
cnckart previously said: View Post
Yup thieves are stupid, that's why they are thieves.
FJ FunJunkie is offline
post #6 of 20 (permalink) Old 02-14-2008, 08:42 PM
PENROSE's Avatar
Quoted: 0 Post(s)
Castille previously said: View Post
What size Terra Grapplers?? 295/70/17? Because I am considering getting that tire in that size and putting them on 17x9 wheels with an offset of 10 (+10 I assume....I think backspacing is like 5.35 inches)
From what you just said....it doesn't sound like my setup would work??
Oh....I got a Rough Country 3" lift in the mail yesterday, so that would be on the FJ too. Didn't order wheels or tires yet.
PENROSE is offline
post #7 of 20 (permalink) Old 02-14-2008, 08:51 PM Thread Starter
Quoted: 25 Post(s)
buddoggin previously said: View Post
WHY WOULD I NEED WHEEL SPACERS??
07 Toyota FJC
Voodoo Blue
4x4
"Modified"
post #8 of 20 (permalink) Old 02-14-2008, 09:04 PM
Quoted: 0 Post(s)
FreshChip119 previously said: View Post
Just to get the wheel out a little, away from things that rub. I don't know for sure that you would need them. I have a 6" lift and still needed the body chop.
Current Mods:
() Fabtech 6" lift
post #9 of 20 (permalink) Old 02-14-2008, 10:03 PM Thread Starter
Quoted: 25 Post(s)
FJ FunJunkie previously said: View Post
I THOUGHT THAT THE 33X12.50X17 ARE THE SAME AS THE 285/70/17 SO YOU WOUDLN'T NEED A BODY CHOP...WHAT IS THE DIFFERENCE IN THE TIRES...ALSO I HAVE 16X8 HELO MAXX 6 WITH 285/75/16 RIGHT NOW WITH NO RUB OR BODY CHOPS OR SPACERS...
IS ANYBODY RUNNING THIS SET UP OR LIKE THIS SET UP...
07 Toyota FJC
Voodoo Blue
4x4
"Modified"
post #10 of 20 (permalink) Old 02-14-2008, 10:05 PM Thread Starter
Quoted: 25 Post(s)
Anybody Have Any Suggestions Of A Rim I Should Go With...
I'm Looking For Black With A Chrome Or Silver Lip 17"
And For Tires Either Mt Or Aggressive At...
07 Toyota FJC
Voodoo Blue
4x4
"Modified"
Human Verification
