Old 04-08-2008, 08:25 AM   #1 (permalink)
Markarian421's Avatar
Member Number: 12916
Maximum BFGoodrich All-Terrain T/A KO size?
First, I'm sorry for asking something I'm sure has been answered before, but my attempts to search for it failed -- if I do any specific search I get no results (to the extent that this morning I'm wondering if the search is even working), last night when I did less specific searches I never found an answer.
I'm trying to get an FJ with 16" wheels (all terrain package). I'd like to put BFGoodrich All-Terrain T/A KO's on it. What's the largest size of this particular tire I can put on a stock FJ without causing problems? It will be going off road. Do I need to stick with the standard 265/75R16? I'm seeing mixed answers about the 285/75R16. I'm not sure the BFG AT T/A comes in anything inbetween.
Thanks.
Markarian421 is offline
Old 04-09-2008, 01:35 AM   #2 (permalink)
Z'sFJ's Avatar
Member Number: 11320
Re: Maximum BFGoodrich All-Terrain T/A KO size?
With the suspension still stock and going offroad the only size available to you would be the 265/75-16. The 285's would only work if your vehicle never left the pavement or you put some type of lift on it. BFG does make a tire that is in between these two sizes. It is the 255/75-17. This size comes in a MT version only. I really don't know of a size that is between those two and uses a 16 inch rim. So, I guess you have to decide just how important is it to have the Off Road package. Hope this helps!
Zane
'07 Black Cherry 5AT, CQ, GY, UR, C8, 2Q, 37, C7, added Toyota ski rack attachments, passenger armrest, 2 rear door storage nets, K&N drop in filter, and a Cyclone air prefilter
Z'sFJ is offline
Old 04-19-2008, 05:24 AM   #3 (permalink)
Member Number: 16998
Do a 3" lift. It's cheap & makes the FJ look perfect. I got the Toytec 3" spacer lift (will be installed tonite) & 285 BFG A/T's(mounting on Monday). Check out the Build threads for members w/3" lifts, You will be ordering in less than a week.My lift was $299.99 shipped. I am having a mech. do install, I don't want to tear it apart myself/ but many
do it themself.
MAXXFJ is offline
Old 04-19-2008, 06:21 AM   #4 (permalink)
Member Number: 14357
I noticed you did not buy the OME front and rear shock with your ToyTec lift. How did it work out?
sandbox31 is offline
