Old 04-10-2008, 01:31 PM   #1 (permalink)
layonnn's Avatar
Member Number: 10006
pro comp series 87 wheel ?
I am about to buy some pro comp series 87 wheels to mount 34x10.50r16 Super Swamper LTB's on. The shop i am going to be getting them from said they can get them in a "16X8 6X5.5 4.25" B/Spacing Pro-Comp Black Rock Crawler wheel".
My question is will these work without a spacer and my OME lift and body mount chopped? I have searched but the only thing i found was this wheel with either a 4" or 4.5" backspacing. So i didn't know if this one would work or not.
I don't know much about wheels and i searched.
thanks guys
Layton
2007 FJ Cruiser 5AT 4x4
Voodoo Blue
"God forgives...rocks don't"
layonnn is offline
Old 04-10-2008, 01:53 PM   #2 (permalink)
Fjamming's Avatar
Member Number: 6623
Re: pro comp series 87 wheel ?
Layton, for some reason this wheel sounds an alarm. I seem to remember that this was one that looks like it would fit, but doesn't. Is this the one that's replaced by another model? Series 97? Sorry I can't say for certain yes or no.
Sandoo Blue FJ
SoCal Events Calendar
Fjamming is offline
Old 04-10-2008, 03:03 PM   #3 (permalink)
layonnn's Avatar
I did a little research on here. And it appears that the 97 won't fit. The holes in the front are pressed in so it leaves a little metal sticking out the back side of the hole and the 87's are laser cut so not metal sticking out the back.
In the two attached pictures, the first one is the 87 and the second is the 97 you can see what i am talking about.
This is what i read from Sbectold in this thread
34" Swamper LTB's, no lift yet, yes/no?
Okay, now i am a little more confused. Wheeler's has this wheel available with a 4" or 4.5" backspacing available. But, my local shop can only get it in the 4.25" backspacing. On procomps website, they also only have the 4.25 in" backspacing as well.
pro-comp-series-87-wheel-16blacksteel1.jpg  pro-comp-series-87-wheel-91steelblack.jpg
Layton
Voodoo Blue
layonnn is offline
Old 04-10-2008, 04:37 PM   #4 (permalink)
WyoOtto's Avatar
Member Number: 11698
Layonn,
I have the series 87 wheel in a 4.5 inch backspace and am running 255/85-16s. I think you'll be okay with your body mount chopped from a rubbing standpoint. As far as the caliper is concerned you have no worries. I might be mistaken but the 4.25" BS should help you from a rubbing standpoint as opposed to the 4.5" like I'm running. Better yet, would probably be wheeler's 4 inch BS. Somebody, please correct me if I'm backwards here.
Painted headlight bezel, Series 87 steelies with 255/85-16 Maxxis Bighorns, ARB full length rack, 60" hi-lift, OME Heavies on all 4 corners, Budbuilts front to back, OEM sliders, Scuba Driver mods, Upper and Lower rear Digger Links, TRD CAI, All-Pro High Clearance tailpipe, Hacked Rear Diff Lock, VSC on-off switch, Custom Expedition One Front Bumper, EPi 9000lb winch with synthetic line, and lots of manual recovery gear and tools.
WyoOtto is offline
Old 04-11-2008, 01:12 PM   #5 (permalink)
layonnn's Avatar
So, now my wheel man tells me he can get the 87 series wheel with a 3.75 inch back spacing.
Wouldn't this put the wheel closer to the brake calipers and the tire even closer to the UCA???
Layton
Voodoo Blue
layonnn is offline
Old 04-11-2008, 05:45 PM   #6 (permalink)
Fjamming's Avatar
Member Number: 6623
Be easier to look at pictures: WHEEL BACK-SPACING & OFFSET: Explained and illustrated
Sandoo Blue FJ
Fjamming is offline
Old 04-11-2008, 06:22 PM   #7 (permalink)
NBFJCruz's Avatar
Member Number: 15365
I hate when this happens.....I too had my heart set on the 97's.....grrrrrr....I really like the "big hole" pattern. Now I read that the old wagon wheel design that Procomp has will work....767 and the 51 I think....
'07 FJ, C package, 5A, Ti
mods so far
Left Foot gas pedal, Silver Star Ultras, FJ Spare Tire Cover, FJ Canvas Storage,more FJ Forum Stickers (Ti), Cruiserland Plate Frames, K&N Drop In, Vent Shades, Extremetrucktoys Level Lift, Garmin 340,aux interior lighting
"A man is what he thinks about all day long"
Barney Bentall
NBFJCruz is online now
Old 04-13-2008, 10:03 PM   #8 (permalink)
layonnn's Avatar
Tony, give me some credit brother. I read that post like 3-4 times. That "x-factor" part that is mentioned was mention in another thread for the 97 series wheel in that it wouldn't fit because of it.
I am looking at around 330 with tax for the wheels from my local shop or 360 for the 4.5 inch bs wheels from wheeler's offroad (both the procomp 87 series wheel). I know the wheeler's wheel fits with larger than stock tires. However, 360 is a lot when i don't even really care about looks, just need them as wheels to mount Swampers. So trying to find some tundra steelies in a 16" still with no luck.
Layton
Voodoo Blue
layonnn is offline
Old 04-13-2008, 10:39 PM   #9 (permalink)
BellyDoc's Avatar
Member Number: 9768
Less backspace means the wheel sticks out MORE, so it's away from the upper control arm... however it swings a wider arc and is more likely to bring the tire up to your body mount chop.
-Jon-
BellyDoc is online now
Old 04-13-2008, 10:50 PM   #10 (permalink)
layonnn's Avatar
Aha, thanks Jon.
My wheel man told me that the only size that he could get in 16 was the 16x8 with 3.75 bs. Would running the 34x10.50 (pizza cutters) be an issue if i had the mount chopped?
Layton
Voodoo Blue
layonnn is offline
