blckmajic previously said:
Looking to purchase the following
Just double checking before ordering to make sure this looks correct as far as Rim Size/Width/Compatibility ect.
If not any advice would be greatly appreciated
Thanks in advance
Nitto Terra Grappler LT295/70R17 D 123R =
200-430 =Stock #
16.5 = Tread Depth
33.19 = Overall Diameter
12.13 = Overall Width
8.0-(8.5)-9.5 = Approved Rim Size
3195@65 = Maximum Load
626 = Revs
and
PXA-7089-7838
Pro Comp Xtreme Alloy Series Black 7089
17x8 - 6x5.5 - Hub Centric - 4.5 BS
With a 12inch wide tire and 4.5 inch backspacing you will be close to the upper control arm. I am not sure if touching or not, but close. If you do rub, a small spacer could be used.
