Old 04-17-2008, 07:28 PM   #11 (permalink)
Member Number: 16506
Re: Just have to vent guys.
i did a rough estimate to the top of the wheel well front was like 36 1/4 and the rear was like 38 3/4s im pretty sure the lift was installed right, a toyota tech did it that has like 20 years experience but it could be wrong. the front gained like 2.5 and the rear gained close to 3 inches which is typical people are saying but if anyones close ill gladly drive to there house to see if its installed right since my camera is broken and wont be fixed for a while.
Mods:
TRD CAI
TRD cat-back exhaust
Tinted front widows
Cobra (75WXST) 3' Firestik.
Piaa 520 Driving lights.
Total chaos skids.
Rain guards.
3 inch OME lift
MY BUILD IS DONE.
nissanaltimacrazyhorse is offline
Old 04-17-2008, 07:39 PM   #12 (permalink)
Mtbcoach's Avatar
Member Number: 2433
Its not always the height but usually the width which causes the rubbing...
Demello sliders
Demello rear bumper
Inchworm Lefty
ARB front air locker
Nitro 4.88 gears
Bud Built skids front to back
Super Swamper SSR 35 X 10.5
Safari Snorkel
Train Hard, Rest Harder
TLCA # 17784
Mtbcoach is offline
Old 04-17-2008, 07:40 PM   #13 (permalink)
MountainMan's Avatar
Member Number: 8491
sounds wrong
flys in the face of everything else we see around here, just dont make no sense...
MountainMan Johnson (blog) WØOZY (447.15 / 146.46 / 147.225) MEMBER: FJ Cruiser Club : NRA : BSA : ARES
Mods: Tint : ClearPlex : Shovel & Axe w/ FourTrex Mount : M-Pac Storage : Blackened Trim : Bandi Mount : Diamond NR770 Antenna : Yaesu VX-7R : Yakima PowderHound : DeMello Round Sliders : DRing Hitch : Recovery Strap : Next_Cooper STT's
MountainMan is offline
Old 04-17-2008, 08:01 PM   #14 (permalink)
homedad's Avatar
Member Number: 10257
dude....they're MT's....with 285/70/17 on OME...NEVER rub....I'm done with you.....
I like Tator Tots...
homedad is offline
Old 04-17-2008, 08:02 PM   #15 (permalink)
layonnn's Avatar
Member Number: 10006
Some maybe be off with your alignment or something if those don't fit. There are some guys running 285's with no lift and not rubbing. The AT's in 285 have a wide shoulder too.
Layton
2007 FJ Cruiser 5AT 4x4
Voodoo Blue
"God forgives...rocks don't"
layonnn is offline
Old 04-17-2008, 08:05 PM   #16 (permalink)
well it needs an alingment but im going to get to the bottom of this.
Mods:
TRD CAI
Tinted front widows
Total chaos skids.
Rain guards.
3 inch OME lift
MY BUILD IS DONE.
Old 04-17-2008, 08:06 PM   #17 (permalink)
FJ4Jake's Avatar
Member Number: 7298
I am running 285/17... with an OME lift... no chop...no rub....
Are you running stock wheels... IF so, you should have no problems... If not, your backspacing has to be way off.....
FJ4Jake is offline
Old 04-17-2008, 08:13 PM   #18 (permalink)
SKIBUMM's Avatar
Member Number: 15003
Something is odd. I just went out and measured mine with a new OME lift Med/Med and stock wheels and Duncraps and I sit 38 1/4 up front and 38 5/8 in the rear to the bottom edge (closest to tire) of the flair. two days ago I had a freind put on 2 295/70/17 Toyo Open Country MT and I might and I say might rub in the most extreme situations and I have no chop.
2007 Black Cherry AT
3" OME lift
Cooper STT 285/75/17
Manik light bar w/ 4 PIAA 520s wired through bar
Domello Hybrid Sliders
Onboard air
Overhead Console w/ Homelink, Maplight
Cobra CB w/ Bandi Mount
XM radio
Afe CAI
Afe TBS
JBA exhaust
Tinted front windows
SKIBUMM is offline
Old 04-17-2008, 08:16 PM   #19 (permalink)
stock 16 inch wheels like i said i just put the 285 next to the 265 didnt actually test fit it so im not sure im just venting because it really looked like it was going to rub i guess some tires rub some dont. I guess i need to find someone with the same setup with 285s.
Mods:
TRD CAI
Tinted front widows
Total chaos skids.
Rain guards.
3 inch OME lift
MY BUILD IS DONE.
Old 04-17-2008, 08:44 PM   #20 (permalink)
88gspd's Avatar
Member Number: 14650
With the OME lift, you should not have over 2" front-to-rear height difference (unless you used 883/895). Are you sure that the front springs were installed correctly? Check the spring seats and make sure that they are not upside down.
EK
2007 FJC 4x4 5AT with some mods
88gspd is offline
