Ok, looking for new shoes but i have a question. Will the 295/75/16 BFG AT's fit with an OME lift? I have heavy up front and med in rear, also i will be mounting them on my TRD 16" rims.
I would like to know if a chop would be needed and if there are any other rubbin issues while wheeling, also what MPG are u gettin whith em?
07 Sun Fuzion FJ 4x4
TRD Rims TRD CAI
Magnaflow Exhaust Pioneer Avic D3
20% Front Window Tint Oznium Dome Lights
OME 886/895 Lift Kit ScubaDriver
XM Radio Cobra CB Radio
285/75/16 BFG AT's
VSC On/Off Switch Atrack/Rear Locker Hack
Future: Rock Rails, Front Bumper? Roof Rack and Light Bar?
it should work out to same diameter as the 295 on 17 inch wheels...as the 75 number is the ration between diameter and height of sidewall. I cant say for sure...but a 33" tire is a 33" tire no matter the wheel it sits on. Give them a measure and see what they come out as.... if a 33" and you are on stock wheels...and using the OME lift sold by ToyTec then you will not need chop and will be fine. Any other lift I cant vouch for...
__________________ I have a high art, I hurt with cruelty those who would damage me.- Archilochus, 650BC
she's a "Brick.......House"
08 FJC, Brick, Auto, Nitto Terra Grapplers (295), ATrac, Locker, Budbuilt skids and sliders, ToyTec 3" lift
Brock runs 33.19x12.13 and says he is fine without chop
Paulthephotographer runs 33.1x11.5 and had to chop, he drives the **** out of his FJC(blue FJC at the build day, "stock" er... trail modified? with mud tires)
your all on the same offset and width wheels
your lift can only prevent rubbing while you're not driving aggressively off road, your suspension geometry does not change because of a 3" lift, your wheels will still travel through the same path as they did with stock suspension, they are just going to start further away from the body/frame with a lift.
if you off road like/with Paul get ready to chop those mounts, Paul's tires even rub up inside of the wheel well, but your taller springs with higher spring rates will help prevent that.
'07 FJC Ti silver 4x2 on steelies, spidertrax spacers and 4x4 springs
'91 240sx (modded to hell and back drift whore)
agree wholeheartedly...the stiffer suspension just takes much more force/weight to travel the same distance as the path is always the same. Think I am going to try to find a 2 foot rock or stump or forklift to raise my back corner so I can put full compression on front and check it out.
I run 295-70-17 and needed a chop plus needed wheel spacers rubbing on the inner control arm.295's are 33.1 a bit taller than normal 33's.
ARB Bumper*OME Heavies*3" Skyjacker rear*Stock Steelies*Nittos Terras 295/70/17*Gobi Ladder*Cobra CB*AP Rock Sliders*Black Bezel*Real Wheels Light Bar*K&N Filter*Choped Body Mounts*Parrot Blue Tooth*Eliminated rear Sway Bar.
