Re: Directional vs. Non Directional Tires?
Dunno if this really applies to trucks, but on my small car, directional tires were quieter and repelled water really well... so well that I didnt have any fear of hydroplaning at all. Plus, I really dont see the reasoning to rotate tires around to "even the treadwear". If my car is messed up and its causing failure to one tire or so, Id much rather fix the problem and put on two new tires than to rotate around the tires to even the wear. Even on my non-directionals, I only rotate front to rear (at most) same side.
BTW.. order up a set of directional (4), and mount a 5th spare from your stock non-directional tires. Keep the original tires/rims and you probably got a lifetime of spare tires for your FJ!
