Old 10-05-2009, 10:35 AM   #71 (permalink)
Member Number: 20378
Re: New Nitto Trail Grappler MT
I think I like these tires. I have the "offroad-package 16" rims" (currently with BFGoodrich rugged trail T/A 265/75R16 tires).
I have a 3" lift and I wouldn't mind going with bigger tires, but I'd need a 285/75R16 right?
KE7JDE/IZ2GMV
manoweb is offline
Old 02-16-2010, 03:45 PM   #72 (permalink)
Discount Tire's Avatar
Member Number: 19426
Wright up added to the OP.
www.discounttiredirect.com
www.myspace.com/discounttiredirect Add us!
We guarantee the Lowest Delivered Price for tires and/or wheels on the web. We'll do our best to match or beat the competition. We offer free mounting and balancing on packages, and a 30-day satisfaction guarantee! We also offer the industry’s best warranty, and no, it's not pro-rated. Purchase our certificates and if anything goes wrong for the life of your tire, we'll replace it for FREE.
Discount Tire is offline
Old 02-17-2010, 11:07 AM   #73 (permalink)
Member Number: 33346
deleted....
shouldn't have posted on DiscountTires post.
OneEyedHito is offline
Old 02-20-2010, 01:07 PM   #74 (permalink)
Member Number: 23376
Can the 285/70/16 fit with out a level kit or is some type of a level kit or lift needed ???
VDBFJ is offline
Old 03-03-2010, 10:44 AM   #75 (permalink)
PowTron's Avatar
Member Number: 27590
Question for Discount Tire Direct:
Is there anyway to have these tires mounted to a set of Liquid Metal Gatlins, THEN shipped to me?
I am trying to be able to do as much of this myself, and not have to schedule an appointment and lug these around to get them mounted somewhere .
2008 Brick = HELGA
Off Road Package
Tinted Windows
Leveled
265/70/17 Terra Grapplers
Future: 3" lift, 295 Nittos, and aux lights and winch
"Hey, it's new to me..."
PowTron is offline
Old 03-03-2010, 12:04 PM   #76 (permalink)
Member Number: 13087
do these come in 285/75/16 or 255/85/16 yet?
wickedpsi is offline
Old 03-03-2010, 12:55 PM   #77 (permalink)
VDBFJ previously said: View Post
Yes. They should fit great without a leveling kit.
PowTron previously said: View Post
Yes, we mount and balance wheel and tire packages for FREE before sending them out. Your only hick-up may be with the TPMS depending on what you want to do. We have a few options for you:
1. We can sell you a new set of TPMS sensors and install them, them mount and balance everything and then ship them to you. New TPMS sensors for the Fj run $88.00 each.
2. We can sell you regular valves and install them, then mount and balance everything and then shipped them to you. Regular rubber valves run $3.00 each
3. If you want to keep your OE TPMS sensors, if equipped, then you will need to take your new wheels and tires to someone locally to have them mounted and balanced. Local charges apply.
wickedpsi previously said: View Post
Doesn't look like it. It looks like the only size available in 16" is the 285/70R16 so far.
Old 03-03-2010, 01:49 PM   #78 (permalink)
Member Number: 29507
Send a message via AIM to genxweb
not to sound completly dumb but all these tires sizes confuse me will these
fit a stock fj with 16 no lift and will they look ok with a 3 inch lift down the road.
Current Silver Stock 2008 FJ: Looking to make some mods.
genxweb is offline
Old 03-03-2010, 02:36 PM   #79 (permalink)
genxweb previously said: View Post
No worries, we are here help.
Stock 16" FJ tires are 265/75R16. This size is appox: 31.65" tall and 10.43" wide. (Some tires run a little bigger some run a little smaller, much like shoes)
A 285/70R16 is appox: 31.71" tall and 11.22" wide.
That said. This tire will be basically the same overall diameter but about 3/4" wider. These will fit a stock Fj (no lift or level) with stock 16" wheels. No rubbing should occur.
If you plan to lift or level your FJ I would recommend doing the lift first and then selecting a slightly taller tire. (285/75R16 with stock wheels) This size will fill up the wheel wells a little better, won't rub when mounted on your stock wheels and will give your FJ a a taller and wider stance. With some modifications you may also be able to run a 295/75R16 on stock wheels with a leveling kit.
Here's a tire size calculator if you wish to compare tire sizes on your own. This will also tell you how far your speedometer could be off if you change your tire size.
Tire Size Calculator
Hope this helps. If you would like further assistance from us please call us at 1.888.459.4080. Anyone here would be happy to help you.
-Travis
Old 03-06-2010, 11:00 AM   #80 (permalink)
Discount Tire previously said: View Post
-Travis
So with a level kit on the front the 285/70/16 might look a little goofy?? I may do a level kit but don't want a full lift kit and don't want a taller tire.
VDBFJ is offline
