Old 11-02-2009, 03:08 PM   #1 (permalink)
Member Number: 30178
Stupid Wheel Locks
Went to install my level lift this afternoon and was foiled by the stupid factory wheel locks. Got one off, put the adapter on the 2nd and realized it was completely stripped. What do you guys recommend? How do I get them off now? Local Pep Boys etc. do not carry a replacement adapter. I was able to tighten the loose one but for the moment I'm hosed. Best I can tell the previous owner allowed someone to use an impact on the lugs as all of them were WAY overtight. If I can I'm gonna just remove all 5 of the stupid things and replace with regular lugs. HELP!
07 TRD Blacked Out, JL Audio Flatwedge, Tint, EZLift Leveling Kit, More to come...
Westbayou is offline
Old 11-02-2009, 03:32 PM   #2 (permalink)
kai38's Avatar
Member Number: 19974
Re: Stupid Wheel Locks
I think a tire shop would have a tool that grabs the outside of the lock nut and with an impact wrench torque it right off.
Kirk,
N31'51.208 W106'37.435
http://www.zoto.com/kai38/albums/19024/
Send Money, Guns & Lawyers..... the _hit has hit the fan!
Beware the man who only has one gun. HE PROBABLY KNOWS HOW TO USE IT!!!
kai38 is offline
Old 11-02-2009, 03:33 PM   #3 (permalink)
Phoenicks's Avatar
Member Number: 3469
That would be my guess too. I'm sure you're not the first to have this happen.
List of mods in order of install:
Passenger Arm Rest
Arizona 4 Wheel Drive Trail Book
Second Horn
Bandi Mount with Cobra CB Radio, 4' Firestick Antenna
Garman Nuvi 650 Navigation
Swapped Out Rubber Mats For Carprted Mats
Factory Rock Sliders
OME 3'' Medium Lift
Wheelers White Steelies
285-75-16 Nitto Terra Grappler Tires
_____________________________
In Memeory of My Beloved Wife Sally November 1954-September 2007
Phoenicks is offline
Old 11-02-2009, 03:46 PM   #4 (permalink)
Member Number: 14683
The dealership put those locking lugnut things on when I took delivery. Once I pulled into my garage, I took them off and have never used them since
It's easy enough to lose the key, or damage the lugnut, leaving you SOL in BFE with a flat tire. They're a farce, any thief worth his salt will have the special socket made by Snap On, MAC, etc, to easily remove the thing
Mac Tools Online Store - LT4000C
If your local tireshop doesn't have this kit, just ask the neighborhood juvenile crackhead car thief
jayman is offline
Old 11-02-2009, 03:49 PM   #5 (permalink)
sephcm's Avatar
Member Number: 17829
I've heard those silly Gator Grip sockets works well. Can't say I can confirm the rumor.
Good luck.
2008 VDB, 4x4, Auto, Off-Road Package, Demello sliders, ToyTec lift with Bilstein 5100's, Ricochet skids, SCUBA ....and some other stuff.
sephcm is offline
Old 11-02-2009, 05:01 PM   #6 (permalink)
Member Number: 31361
Just wire weld a any large hex nut on it and take it off with a regular wrench. "you weld on the inside dia of the nut.
sharp is offline
Old 11-02-2009, 05:32 PM   #7 (permalink)
FJYOU!'s Avatar
Member Number: 21712
sharp previously said: View Post
I'll file that little tid bit away. Great idea! one of those really simple things that makes me wonder why I didnt think of it.
REP POINTS!
FJYOU! is offline
Old 11-02-2009, 05:38 PM   #8 (permalink)
rotorhed1's Avatar
Member Number: 7308
Once I lost the key to some lugnuts. I got in there with a die grinder and ground the sides of the nuts flat. Then used a crowsfoot on an extention. It worked.
http://www.discounttiredirect.com/ I win!
rotorhed1 is offline
Old 11-03-2009, 03:21 AM   #9 (permalink)
Member Number: 23595
Westbayou previously said: View Post
Just go to a Toyota dealer..... they have a complete kit for all eleven different pattern........and replace these stupid wheel locks with regular nuts....that's it !
fjqc is offline
Old 11-05-2009, 03:14 PM   #10 (permalink)
Member Number: 14612
Location: Michaux State Forest Adams County Pennsylvania
The dealership ought to have a complete set of those keys. Mine does, so I never give them mine when in for rotation.
Logansky is offline
