Toyota FJ Cruiser Forum - View Single Post - adjusting headlights
post #4 of (permalink) Old 09-16-2006, 04:57 AM
MIAMIFJ
Quoted: 0 Post(s)
Re: adjusting headlights
STOP!!! Toyota would not require you to remove the grill assembly to adjust the elevation of your headlights. Maybe Lexxus but not TOYO. This is an SUV after all. I Installed My Rough Country Lift Last Week. There is a headlight adjustment channel on the top of the cover. It is a hole and you can actually see the bolt. All You Need Is A Long Flat Head Screwdriver. The bolt sits on a cam just like the one on a hose clamp. Turn it clockwise To Go Down, Counterclockwise To Go Up. Email Me If You Need Some Picks. This Is Only For The Elevation Alignment. I Am Afraid That If Yo Need To Adjust The Aim, you are screwed and would have to follow White Rim's direction. Believe Me, You Do Not Need To Take Off the Grill. You can actually see the channel on White Rim's diagram (top of "A" bolt). They would not put the channel unless you could use the channel. Remember, your baby was built in Japan not Detroit.......
MIAMIFJ is offline
