Toyota FJ Cruiser Forum - View Single Post - 3" Lift & Headlight Issue
post #7 of (permalink) Old 07-24-2011, 12:48 AM
Fedaykin
Quoted: 0 Post(s)
Re: 3" Lift & Headlight Issue
FJ Reno previously said: View Post
Did a 3" lift and it appears that my FJ is lower in the back than front in which case trucker's don't like my lights pointing up at an angle. Has anyone else had this problem? Best fix?
Are you trying to fix the lift or the headlights? The lift will settle, more in the front than in the rear. The headlights can be adjusted by turning a small wheel located on the back of the headlight housing. Hope this helps.
Fedaykin is offline
