Toyota FJ Cruiser Forum - View Single Post - Why does the paint suck so bad?
post #18 of (permalink) Old 07-14-2012, 02:14 AM
Sgt Casta
Quoted: 5 Post(s)
Send a message via AIM to Sgt Casta
Re: Why does the paint suck so bad?
Hellbound13 previously said: View Post
So a bird **** on my FJ. Not thinking I washed it off using a microfiber and some detailer spray instead of washing it. It scratched the paint to hell. Marks all over. I understand I should have washed it, but wiping off with a rag and some spray should not cause that. Whats with the paint on these things?
Sounds like you may have wiped with the bird **** in between the microfiber cloth and the paint causing the scratches. Best method would be to soak the bird **** with detailer spray until it is soft and then lift the bird **** straight off the paint using a detailer cloth. Next, spray the area again and wipe away using a damp (detailer spray) microfiber cloth, while either changing or rotating cloths in between wipes.
Sgt Casta is offline
