4X4 with "Crawl" - Grinding noises..... - Toyota FJ Cruiser Forum
post #1 of 22 (permalink) Old 03-10-2014, 05:02 PM Thread Starter
Boudreaux's Avatar
Quoted: 9 Post(s)
Smile 4X4 with "Crawl" - Grinding noises.....
New owner here:
I'm trying to learn my FJ. I have read the manual over & over. It reads as very simple to use the "CRAWL" system.
I put the vehicle (Automatic transmission) in 4D/L4 everything is fine. Then I push the "crawl Button" to on. When I released the brake, I get this horrific noise that sounds like grinding gears. So I stopped within a foot or so, and turned CRAWL off.
I also tried 3D/4L & 2L/4L with the same serious grinding results. The manual indicated to expect sounds from the front compartment, but I don't think this is what they are talking about ...... ANY IDEAS WHAT I'm DOING WRONG.
Boudreaux is offline
post #2 of 22 (permalink) Old 03-10-2014, 05:26 PM
msduncan's Avatar
Quoted: 241 Post(s)
Re: 4X4 with "Crawl" - Grinding noises.....
Hmmm.... that almost sounds like what I remember A-Trac sounding like. But wait for someone that knows more about it to respond.
2010 Brick "Predator" FJC | LCNW 3 Hoop Bumper | Toytec/Eibach 112-620 front springs | Toytec Superflex rear springs | Bilstein 5100 adjustables | Viper 12,000 lb winch | 285/75/16 Falken Rocky Mountain ATS II | Pure Rock Sliders | RCi Metalworks Engine Skid | Spidertrax 1.25 wheel spacers | Skyjacker sway bar extended links
msduncan is offline
post #3 of 22 (permalink) Old 03-10-2014, 05:59 PM
Quoted: 1 Post(s)
Don't think you're doing anything wrong. Try adjusting the speed with the rotary knob. When you get the right setting it should stop grinding. I think it's just getting the speed right for the available traction.
NoSkills is offline
post #4 of 22 (permalink) Old 03-10-2014, 06:25 PM
Admin
Winterpeg's Avatar
Quoted: 2462 Post(s)
I don't have crawl.... so my question is does the driver have any throttle input or does the crawl control all throttle input?
Suck it up... it's only -40
2008 FJ Trail Teams
ARB Front; Exp1 rear STC; Apex rocksliders; Lightforce on front bumper; ARB Full Rack w/Grid; ; Icon Susp w/cdc; magnaflow muffler (mashed the original); Engo 12000S winch; 285/75/16 Duratracs; Ricochet skids, Uniden PC78 Elite CB (ch 16 typically, ch 19 on the hwy)
"Don't drive angry".... BFM
Winterpeg is offline
post #5 of 22 (permalink) Old 03-10-2014, 06:28 PM
Lmmmmm's Avatar
Quoted: 137 Post(s)
what terrain were you practicing on
2011 NSSE - Icon coilover - TotalChaos UCA - SAW rear coils - OME 895 rear medium shocks - Metal Tech slider - Metal Tech tube bumper - Viper Elite 10k Winch - PIAA 520 ATP - Midland 75-822 CB - Boztec antenna mount - Duratrac 285/70x17 - Scuba Mod - Ricochet skids - PIAA dual horn 400/500 - sPOD - Ellis Stealth Shift Knobs - MPAC rear/side rack - PLX Kiwi Bluetooth OBDII - Nestah Edition Firestik Radio Antenna - National Luna Single Battery Monitor - Tantrum Rock Lights - Outrider Shock Armor - Toy Outfitter LCA - Switched DRL's - Front rock cameras - Custom Rear Cargo Storage - Platinum PM-1 Battery - Raingler Cargo Nets - 10LB Powertank
Lmmmmm is offline
post #6 of 22 (permalink) Old 03-10-2014, 06:29 PM
CEC_LDO's Avatar
Quoted: 10 Post(s)
Your FJ will make all kinds of noises when in CRAWL mode. The computer is modulating both the brake and glass to maintain an exact speed (controlled by the dial). You'll notice when you're going uphill or downhill there will be much less noise since gravity is causing it to work only one or the other....relax. It's all good.
Sent from my Galaxy SIII
CEC_LDO is offline
post #7 of 22 (permalink) Old 03-10-2014, 06:30 PM
Quoted: 1 Post(s)
From the 2 times I played with it, CRAWL controls throttle and brakes. And I believe if you foot brake it will turn CRAWL off. I don't know what the system would do if you added additional throttle.
NoSkills is offline
post #8 of 22 (permalink) Old 03-10-2014, 06:49 PM
Lummer's Avatar
Quoted: 23 Post(s)
Cec said it right. Nothing wrong with it. Just sounds horrible.
enjoy the neck exercise!
Lummer is offline
post #9 of 22 (permalink) Old 03-10-2014, 07:33 PM Thread Starter
Boudreaux's Avatar
Quoted: 9 Post(s)
Smile Re: 4X4 with "Crawl" - Grinding noises.....
I was trying Crawl on my 150' cement (level) driveway. I know that may not be the best place to test it. BUT, I expected that when set into motion, the system would just crawl along like it should do while in 4x4 with controlled crawling speed, then when needed, the engine would kick in and make the climb or descent.
I just can't believe that those horrific grinding noises are normal. The noises are really overwhelming.
Thanks for the responses.
post #10 of 22 (permalink) Old 03-10-2014, 07:36 PM Thread Starter
Boudreaux's Avatar
Quoted: 9 Post(s)
NoSkills previously said: View Post
On those two occasions you played with the CRAWL System, did your vehicle make that horrific grinding noise when you hit the crawl button and released teh brake.....???
