Proper use of recovery gear - A how to discussion - Page 8 - Toyota FJ Cruiser Forum
 82Likes
post #71 of 82 (permalink) Old 12-28-2014, 02:52 PM
Desert Moderator
amaclach's Avatar
Quoted: 2943 Post(s)
Re: Proper use of recovery gear - A how to discussion
Ti Toaster previously said: View Post
Got to be honest, I have tried this, and it works.
Granted, I did it twice and it was ugly both times, but in the end it finally worked.
It cracks me up that no matter where you are, what country, what culture, and what language you speak there are certain universal truths:
1) Everyone gets stuck
2)There are always 15 guys standing around barking at you.
3)Every man in every culture and in any language really feels the need to tell you how to do everything, or tell you how you are doing it is wrong.
Awesome! - burying the spare tyre would also work if you don't have a sandbag handy.
Black '14 6MT
Stock bumpers
Some mods
Rear Diff Lock on Demand mod: https://www.fjcruiserforums.com/foru...mand-hack.html
Nannies Off Mod: https://www.fjcruiserforums.com/foru...ml#post1183262
amaclach is offline
post #72 of 82 (permalink) Old 12-29-2014, 05:36 AM
Quoted: 21 Post(s)
amaclach previously said: View Post
Maybe also consider how to deal with a tyre pop-off (again - you really need a hi-lift, lift-mate and compressor for this) - this can easily be done alone with the wheel on the car. http://www.youtube.com/watch?v=KEtdtapiXGA demonstrates a safe technique.
The guy is a bit goofy, but that is a heck of a lot safer than the fire technique I have seen used before. Thanks!
2013 Trail Teams Special Edition
"Spook"
**always a work in progress**
ejcagle is offline
post #73 of 82 (permalink) Old 12-29-2014, 07:06 AM
Desert Moderator
amaclach's Avatar
ejcagle previously said: View Post
Yeah - there's a lot of rednecks using engine start on youtube. Personally I have never needed the ratchet strap - I just put the compressor on and pull the tyre toward me from each side while bracing against the rim with my foot while it's up on the hi-lift. quick & easy.
ejcagle likes this.
Black '14 6MT
Stock bumpers
Some mods
amaclach is offline
post #74 of 82 (permalink) Old 01-21-2015, 10:26 AM Thread Starter
sweptwingnut's Avatar
Quoted: 248 Post(s)
The following PDF files have been added to post one. Both are excellent reads for all experience levels.
File Type: pdf Winching without the Worry | Expedition Portal.pdf (2.15 MB, 253 views)
File Type: pdf Pirate4x4.Com - Extreme Four Wheel Drive (recovery bible).pdf (1.52 MB, 269 views)
BlindWilly likes this.
My Build Thread - The Boontoolies
sweptwingnut is offline
post #75 of 82 (permalink) Old 01-04-2018, 04:19 PM
Quoted: 3 Post(s)
Assuming "light duty" recovery, e.g. snow drift, muddy creek crossing, what would folks recommend as the minimum winch capacity? I'm leaning towards a Warn 8000, but want to make sure I shouldn't have gotten a 10K.... Thanks!
arcsound is offline
post #76 of 82 (permalink) Old 01-04-2018, 10:24 PM
gearwrench's Avatar
Quoted: 482 Post(s)
Hey guys I am rechecking this thread and suggest that it's a thread that everybody should revisit just from a safety standpoint. When I first visited this thread I was a nooby and approached as such with the attitude "I don't have a winch but the guy that does will know what to do", this IS NOT always the case. I have seen people using a winch that I wouldn't trust with a block and tackle. Also from a pure safety stand point the information is valuable. Hi lift jacks, snatch straps and "D" ring shackles are all a part of offroading and should be treated with much respect and the more knowledge you have the more likely all the rigs and all the humans will return from a day on the trails in tact.
KC3JJX
gearwrench is online now
post #77 of 82 (permalink) Old 01-06-2018, 06:15 AM
TALON316's Avatar
Quoted: 9 Post(s)
I was thinking the hitch pin could be the weakest link after watching some of the videos. What would be a good/great hitch pin to buy?
TALON316 is offline
post #78 of 82 (permalink) Old 01-08-2018, 09:54 AM
BlindWilly's Avatar
Quoted: 843 Post(s)
arcsound previously said: View Post
I went with a superwinch tigershark 9500, or close to 10k.
I've used it to recover other folks, not myself yet.
I think, and I'm sure smarter folks will/should chime in, that going with the 10K is better for recovering your rig and others.
Proud owner of "Muddy", my 2013 Quicksand FJ.
http://www.txpedition.com
"No Matter Where You Go, There You Are"
-Buckaroo Bonzai
BlindWilly is offline
post #79 of 82 (permalink) Old 01-08-2018, 05:30 PM
Iconic_'s Avatar
Quoted: 2659 Post(s)
While I think the 8k is good enough to get you out of 95% of situations considering I often hardly have to pull with my Warn 9.5 to get myself up an obstacle. I have during extreme use nearly stalled my winch (with the motor running to supply more power) on one or two very strong pulls. One of them the other FJ was at a very steep incline with a front tire needing to get pulled up about a 3 ft bump and the rear bumper was pulled over a stump. I was at the top of the hill pulling up. Most of the time I'm surprised with what little effort it takes. Also dual batteries helps quite a bit to supply more power on the harder pulls. I only have one big battery. If I had to replace my 10 year old 9.5 Warn, it would be with a bigger one. BUT like I said for most situations its not usually needed.
Iconic_ is online now
post #80 of 82 (permalink) Old 01-08-2018, 06:22 PM
FAUJI's Avatar
Quoted: 381 Post(s)
Thumbs up Re: Proper use of recovery gear - A how to discussion
excellent thread sweptwingnut and great discussion
FAUJI is offline
