Rear locker slow to engage and disengage - Page 2 - Toyota FJ Cruiser Forum
post #11 of 17 (permalink) Old 08-11-2007, 08:58 PM
Briman42487's Avatar
Quoted: 0 Post(s)
Re: Rear locker slow to engage and disengage
homedadr previously said: View Post
STOP....don't do it on the pavement!!!!
and email me if you are still lookin' for a job
ehh, its fine on the pavement.
i emailed you a while back.
[email protected] right?
Briman42487 is offline
post #12 of 17 (permalink) Old 08-11-2007, 09:03 PM
White Rim's Avatar
Quoted: 0 Post(s)
the locker splines may not be lined up when you engage the button, so the locker will not engage until they are. Experience seems to suggest that weaving back and forth on the trail will alter the rotation speed of the rear wheels with respect to each other enough to cause spline alignment and engage the locker.
Disengagement requires there to be relatively little differential torque between the wheels so the splines can disengage. Again, just rock the steering wheel back and forth a little and it will disengage.
BC MT6, Pkg2, KOs, rack, rails, Warn clevis hitch, tungsten Abrams shifter, I-Way, Baja 480C, 300W maplight, aux backuplights, aux battery w/ separate house power incl 3 12 v sockets, gerrycan rack, 3 OD Scepter MFCs, 2 black Scepter MWCs, 1500 inverter, dead buzzers/DRL, 1 kilowatt incandescent camp light, Iridium
White Rim is offline
post #13 of 17 (permalink) Old 08-11-2007, 09:04 PM
SonicFJ's Avatar
Quoted: 0 Post(s)
you might have wanted to engage all your toys BEFORE attemting that climb...mid trip is a little too late...with locker and A-trac that would have been an easy climb
Absolutely operator error...However;
1. It was before I did the hack, so I only had one or the other.
2. I tried it with Atrac before backing up and switching to the locker.
3. I was back into the obstacle and still waiting for the locker to lock when I gave up on it, and decided to run it anyways. (I should have backed up again and tried to get the locker to come on again).
Live and learn.
SonicFJ is offline
post #14 of 17 (permalink) Old 08-11-2007, 09:05 PM
fj4M&E's Avatar
Location: Co most of the time but live in the UK for now
Quoted: 1 Post(s)
I have messed with the locker a little bit and since I was new to e lockers the book says it may take a few seconds to line up. That is not a quote but the gist of it.
Black fj loaded
arb bumper
IPF aux light
warn xp 9.5
viking synthetic winch line
PIAA 525 lights
king shocks
Budbuilt skids
Toytech Rr lower control arm
All pro Lower link skid
Total Chaos upper "A" arm
duel battery
Gobi roof rack
32" xmitter light
delta fog on the side
PIAA 2100 fog on the rear
fj4M&E is offline
post #15 of 17 (permalink) Old 08-11-2007, 09:07 PM
Quoted: 1 Post(s)
Send a message via AIM to SupraTuRD Send a message via Yahoo to SupraTuRD
White Rim previously said: View Post
Well said, exactly what I was going to post.
Fender Bulge Problem Resolved.
Solution: 100 Series.
SupraTuRD is offline
post #16 of 17 (permalink) Old 08-11-2007, 09:21 PM
BellyDoc's Avatar
Quoted: 4 Post(s)
First off, the elocker needs "permission" in the form of a switch being contacted inside your transfer case by the shifting mechanism. If you're not in 4 low, it won't be allowed to activate. If you want to be able to run it in 4 high for some reason, or in 2wd, you could hack the switch with little difficulty, but I personally don't have any use for that. Perhaps people who want to drag race their FJ's or tow big boats up wet ramps might... I don't know.
Secondly, the elocker involves two gear mechanisms that are linked, one each, to the rear axle shafts. One is fixed and the other can slide. The slider is spring loaded to open away, and closes down to engagement based on the solenoid-like action of the electric mechanism. When they are interlocked, the right and left axle shafts twist as one, and the differential gears are essentially bypassed. The mechanism becomes a "spool".
The problem is that there is no guarantee that when you hit the switch, the gear teeth are lined up to engage. They are just as likely to come together tooth-on-tooth as they are tooth-on-valley (the latter being how it has to happen for the mechanism to "click"). If it comes together tooth-on-tooth, then it will remain NOT ENGAGED until one axle shaft rotates relative to the other.
The condition that causes one axle shaft to rotate relative to the other is TURNING.
Engage the locker on good ground. If it doesn't engage immediately, drive forward or backward IN A TURN. As soon as you get one rear wheel to rotate a bit more or less than the other, you'll hear it click in.
-Jon-
BellyDoc is offline
post #17 of 17 (permalink) Old 08-12-2007, 06:09 PM Thread Starter
Moderator
opg4759's Avatar
Quoted: 0 Post(s)
Thanks for all the feedback.
I was overanalyzing a problem I didn't have, and being used to air lockers. It seemed as if I had a problem with my rear locker.
This all stemmed from my A-Trac hack failing due to a t-tap that didn't cut into the wire very well. The funny thing is that it worked for about 9 months before failing, must have been the drive back and forth to Ouray that knocked it out of kilter. I ended up hacking the wiring apart and soldering longer jumpers inline I have to say that it looks cleaner now.
I was trying to test everything and it all seemed very slow to engage. I tried the turn my wheels while moving forward and that did the trick. I just need to remember this on the trail.
NUFC
Rig
Black Diamond M/T, Bandi antenna mount/ Yaesu FT-7800r, 4 Piece Budbuilt Skids(still need the gas tank skid), OME 886/895, All-Pro upper and lower links, Procomp 7089, Procomp Extreme M/T's, Project Overkill rails, BozTec diff Skid, sPOD.
Always trust the Gene Genie
1985 FJ-60 Very stock, evil plans in store.
opg4759 is offline
  Similar Threads
Rear Locker ? i8hotdogs Problems / Dealer Service 11 11-29-2007 08:38 AM
rear locker grusso 4x4 / Off-Road Tech 6 02-26-2007 10:51 AM
Do I have a rear locker? Teamsobaco 4x4 / Off-Road Tech 50 02-16-2007 07:08 PM
Rear locker Slab General Discussion 20 08-04-2006 04:24 PM
Center Locker? Rear/Front Locker? K_os General Discussion 3 02-12-2006 08:44 PM
