Crawling - Page 3 - Toyota FJ Cruiser Forum
 44Likes
post #21 of 39 (permalink) Old 05-27-2019, 07:16 PM
Forum Beer Miester
Thorn661's Avatar
Quoted: 2067 Post(s)
Re: Crawling
Firemedic831 previously said: View Post
Yes 4 speed . I would wait and talk to Marlin.
Yea after visiting with CabinCruiser a bit today I do believe theyíre the way to go even if I do have to slightly mod the fuel tank. CC said they also make driveshafts so thatís a plus also.
CabinCruiser likes this.
Thorn661 is offline
post #22 of 39 (permalink) Old 05-27-2019, 07:24 PM
Iconic_'s Avatar
Quoted: 2617 Post(s)
Re: Crawling
You don't have to mod the tank for any atlas install. its only for the dual case "tacobox" since you are essentially using 2 cases it only works well in the long wheelbase tacoma.
https://www.fjcruiserforums.com/foru...r-case-12.html
Thorn661 and Firemedic831 like this.
Iconic_ is online now
post #23 of 39 (permalink) Old 05-27-2019, 10:39 PM
Forum Beer Miester
Thorn661's Avatar
Re: Crawling
Yea but I really want to retain my factory case and utilize a doubler. The only way I can do that with the Atlas is use the 4 speed which has its own doubler in a manner of speaking. I just donít want to spend that amount of coin for it when itíll take body mods including removing heat shielding and reshaping the tunnel then installing a triple shifter oh and I would have to build a crossmember and adapter for it or risk failure. Iíve heard theyíre kinda noisy too, probably sounds similar to my AA overdrive in my 40.
I love the things but weighing pros vs cons along with the modifications needed and costs I think the TacoBox wins out for me. If I were ever thinking about going SAS I would consider it maybe but I donít ever foresee that as a possibility.
Thorn661 is offline
post #24 of 39 (permalink) Old 05-27-2019, 11:02 PM
Iconic_'s Avatar
Re: Crawling
Either way its gonna be the last thing I have planned for my FJ so I'm just gonna wait and see what Marlin comes out with.
post #25 of 39 (permalink) Old 05-28-2019, 08:14 AM
Forum Beer Miester
Thorn661's Avatar
Re: Crawling
I’ll be speaking with Mike this week if possible, I visited with them last year and checked out the TacoBox. Solid unit.
Thorn661 is offline
post #26 of 39 (permalink) Old 05-28-2019, 08:55 AM
Forum Beer Miester
Thorn661's Avatar
Re: Crawling
There’s two reasons I want the crawl box.
First is wear and tear on the drivetrain on climbs reducing or eliminating shock load and over heating causing premature wear. Second is that I can easily see myself bumping up to 37’s at some point and that will definitely add too much stress to the drive line.
The only issue I’m concerned with is being left with essentially an open front diff in Lo Lo at 206/1 ratio. I’m still rolling with A-Trac so my concern is with the ultra slow tire rotation will the A-Trac still sense traction loss and compensate? Maybe @CabinCruiser or @gearwrench will have some thoughts on this.
Thorn661 is offline
post #27 of 39 (permalink) Old 05-28-2019, 09:42 AM
トヨダ Master
CabinCruiser's Avatar
Quoted: 3384 Post(s)
Re: Crawling
Thorn661 previously said: View Post
Thereís two reasons I want the crawl box.
First is wear and tear on the drivetrain on climbs reducing or eliminating shock load and over heating causing premature wear. Second is that I can easily see myself bumping up to 37ís at some point and that will definitely add too much stress to the drive line.
The only issue Iím concerned with is being left with essentially an open front diff in Lo Lo at 206/1 ratio. Iím still rolling with A-Trac so my concern is with the ultra slow tire rotation will the A-Trac still sense traction loss and compensate? Maybe @CabinCruiser or @gearwrench will have some thoughts on this.
A-trac doesn't care what speed you are going, the only confusion might be that it tries to control when actual speed will be compounded with the new lower gears. It's reaction time is probably slower than how the drivetrain behaves if it is reliant upon VSS in the drivetrain vs the speed sensors at the wheel. I don't think it's adaptive learning but perhaps @FJtest could chime in on the specifics of A-Trac and how it will function with compound low range. Good question, Thorn.
Thorn661 likes this.
R.I.P.- Echo
Solitude Allows One to Reflect While Others are Reacting...
It Is Easier To Walk On Hot Coals Then It Is To Walk On Egg Shells...-CC
Member of the month-October 2017
CabinCruiser is online now
post #28 of 39 (permalink) Old 05-28-2019, 09:57 AM
トヨダ Master
Re: Crawling
They are straight cut gears similar to your OD, and got their design inheritance from the venerable NP205 and Dana 300 transfer case. Most people fight drivetrain noise with one of these and a simple clockwise turn of the radio dial.
R.I.P.- Echo
post #29 of 39 (permalink) Old 05-28-2019, 10:24 AM
Firemedic831's Avatar
Quoted: 534 Post(s)
Re: Crawling
Thorn . i would contact . Wyatt . from Rock Solid Toys They install both the Marlin and Atlas he will give you a unbiased opinion . They will also know what you will run into .
09 AT Toytec Boss performance 3inch lift, Demello sliders , TRD brakes , MT offset Lower links . Rad Rubber splash guards ,Cobra CB,
Firemedic831 is online now
post #30 of 39 (permalink) Old 05-28-2019, 10:32 AM
Forum Beer Miester
Thorn661's Avatar
Re: Crawling
CabinCruiser previously said: View Post
Appreciate the input CC I hadnít thought about the drivetrain sensors not understanding why the wheels arenít achieving an expected speed, all I had thought about was the wheel sensors spinning too slow. Food for thought, letís see what Test has to say.
Thorn661 is offline
  Similar Threads
IFS Crawling Flex - Another Review/Measurement of Total Chaos +2" LT HeisKai Suspension / Steering Tech 4 10-17-2015 04:09 PM
Extreme rock crawling.... Judge Roy Bean General Discussion 7 02-08-2015 05:53 AM
On a tight Budget.....Go Mall crawling! mad_mechanix Off-Topic Discussion 17 01-13-2012 09:19 PM
rock crawling on "MODERN MARVELS" tv show FJ FunJunkie General Discussion 3 02-06-2009 08:18 AM
Wreckreation Nation - Rock Crawling Crawlin95 Off-Topic Discussion 5 01-14-2009 08:24 AM
