Toyota FJ Cruiser Forum - View Single Post - Is this a good deal?
post #7 of (permalink) Old 01-26-2017, 01:55 PM
CurbCrawler
CurbCrawler's Avatar
Quoted: 143 Post(s)
Re: Is this a good deal?
As other mentioned, do your service and damage research well (Toyota Service history or CarFax or?). Make sure it is 4WD and determine the options it has. If you are serious, ask if you can take it to a professionals shop on a test drive to have it looked over, that may give you some piece of mind? If the dealer cringes at that request, that may tell you something also? Don't be afraid to crawl underneath it and look it over for bent, broken or scrapped parts, oil leaks and grease spray or torn rubber. Maybe you could talk with the previous owner? MO would be, that if there is nothing wrong with the vehicle, for $15k the price is right! GL
The reason why we retain memories is because we are not caught in a time loop. The reason why we are not caught in a time loop is because it is not possible to go backwards in time only forward!
*CurbCrawler fabricated hidden front receiver.
*CurbCrawler fabricated Hi-Lift receiver mount.
*CurbCrawler fabricated SS dual battery tray & Walmart Battery.
*CurbCrawler fabricated 4-Gauge dash pod.
*CurbCrawler fabricated Aux fuse/relay panel.
Gibson cat-back exhaust (Dyno Proven)
Complete set of aluminum skid plates.
Receiver mounted 9k-lb rear winch.
Hayden trans cooler w/electric fan.
Factory rock rails.
Moon roof.
LED fog & backup lights.
Husky mats: front, center & rear.
CurbCrawler is offline
