I HATE Soldering PL259 connectors - Page 2 - Toyota FJ Cruiser Forum
post #11 of 13 (permalink) Old 05-18-2013, 08:52 AM
NW FJC's Avatar
Quoted: 310 Post(s)
Re: I HATE Soldering PL259 connectors
All really good info, the one trick I use in addition is a little extra flux and a dab of solder to start heat transfer between the item being soldered and the iron on big items that need or soak extra heat... The heat "connection" helps to get in and get out without excessive heat soak... Let the solder joint cool naturally without disturbing until solid then use canned air upside down to cool the rest of the way and clean up with denatured alcohol and Q-Tips... 73's
NW FJC is offline
post #12 of 13 (permalink) Old 05-18-2013, 09:50 AM
Slow's Avatar
Quoted: 0 Post(s)
Mr R2FJ previously said: View Post
It's a mobile application so RG-8X. I've got a 260W gun, which at the time was one of the hottest I could find. I'm just not having a lot of luck getting the work hot enough to flow the solder onto it. I was using rosin core but maybe I'll try a smaller diameter solder. Thanks for all the replies. After reading qrz apparently I'm not the only pl259 connector inept person out there.
IMHO I would ditch the gun and get a 40-60w pencil with a chisle tip it will make life easier. Make sure the tip is cleaned and tinned to help with propper heat transfer. 73
Slow is offline
post #13 of 13 (permalink) Old 05-22-2013, 06:05 PM
WD9ICU's Avatar
Quoted: 4 Post(s)
After 48 years of soldering I bought a crimp tool a couple dies and an assortment of connectors. No problems.
Awww...life is good!
Sent from AutoGuide.com App
2011 Quicksand
285 17 Duratracs, Radflo 2.5 system, light racing UCA, "BMC",Metal Tech LCR& OPOR sliders, Ricochet skids, Expedition One bumpers,National Luna battery control, Sears Battery, Superwinch 9.5/AmSteel Blue, Factor 55 prolink, ARB fridge, Piaa 510 fogs, Little TarHeel HF screwdriver, Larsen 2/70 ant., Yaesu FTM400DR, Yaesu Ft897D hf, CB radio. Various odds n ends....
WD9ICU is offline
  Toyota FJ Cruiser Forum > Toyota FJ Cruiser Discussion > Stereo / Electronics / Electrical > CB / HAM / Communications
