Where to run heavier ga wire thru the firewall? - Page 2 - Toyota FJ Cruiser Forum
 3Likes
post #11 of 19 (permalink) Old 09-24-2013, 09:02 AM
Quoted: 14 Post(s)
Re: Where to run heavier ga wire thru the firewall?
My 710 is mounted on the dash. I Velcro'd the factory mount and ran the cable through the dash and out under the gauge cluster. Had to make a relief in the base of the cluster.
The transceiver is mounted under the drivers seat on a homemade bracket.
Still not 100% on where the mic will end up. Right now it rests in the front cup holder.
Yes it blocked the compass, but I can turn on the GPS and get compass readings from the radio.
-Life is not measured by the number of breaths we take, but by the moments that take our breath away.
C-Fish is offline
post #12 of 19 (permalink) Old 06-13-2014, 07:54 AM
FJ&TJ_Dude's Avatar
Quoted: 276 Post(s)
Mikeys_FJ previously said: View Post
The boot on the passenger side behind the glove box is pretty big. I have a couple smaller wires going through there but you could run a much larger wire through that baby.
Isn't that black small plug next to where you ran your wires a rubber firewall gromet that toyota installed in case someonewants to run wires and all we have to do is make a slit in it? Just curious as it serves no other function does it??
Thank you Vets
FJ&TJ_Dude is offline
post #13 of 19 (permalink) Old 06-13-2014, 06:47 PM
Quoted: 96 Post(s)
shopsaw previously said: View Post
Try the firewall bulkhead boot on the passengers side (~3" rubber, below the hood hinge). This is the same one that has the rear windshield washer hose, and is outboard of the larger boot that carries an electrical bundle.
This is where I ran my 8ga. for my TM-710 and other needs. Hope this helps!
Its a good way inside.
I ran...
1) 2ga for amp
1) 6ga for rear distribution fuse panel, radios and chargers
1) 8 conductor belden HD rotor wire for my relays to switches control lead
4) 14ga for relay to roof lighting
1) 14/2 for rear bumper lighting
All through that rubber boot
DX FJC
I'm on my phone because I'm screwing off...
2011 Army Green
3" extended travel Icon coilovers with King springs, Icon expedition rear springs, Icon shocks
Total Chaos arms front and back
305/70R17 Goodyear MT/R's on Hutchinson beadlocks
TRD air box, Safari snorkel, Flowmaster cat back, URD off road pipe
Rigid Industries light bar and duallys, Piaa ion fogs and white driving,
Whelen ion strobes, Ricochet skids, Springtail M-pac,
and lots and lots of radio gear
DX FJC is offline
post #14 of 19 (permalink) Old 06-23-2014, 08:39 PM
carlgcs's Avatar
Quoted: 2 Post(s)
DX FJC previously said: View Post
I ran...
1) 2ga for amp
DX FJC
Yup, I ran (2) 2ga cables through the drivers side grommet along with several 10ga wires without issue.
The FJC is very forgiving when it comes to running cables!
Build Page
TLCA #19572
GCLC #2129
YANKEE TOYS
FJNortheasters
carlgcs is offline
post #15 of 19 (permalink) Old 07-01-2014, 04:43 PM
Mikeys_FJ's Avatar
Quoted: 8 Post(s)
FJ&TJ_Dude previously said: View Post
Yes indeed it is.
Dirty Squirrel
2013 Iceberg
Mikeys_FJ is offline
post #16 of 19 (permalink) Old 07-02-2014, 04:17 PM
Dennx's Avatar
Quoted: 91 Post(s)
One of the most perfect places to run heavy gauge into the cab. Drill a new hole and install a gland nut appropriately sized for the wire. 1/0 AWG for 2 Alpine PDX amps.
My Photos - My Build - K6DNX
Managing Editor, TCT Magazine
Dennx is offline
post #17 of 19 (permalink) Old 07-02-2014, 04:23 PM
A-Team Moderator
Hannibal's Avatar
Quoted: 2633 Post(s)
Dennis, as always, FIRST CLASS all the way.
Dennx likes this.
2011 NSSE
トヨタ
Hannibal is offline
post #18 of 19 (permalink) Old 07-02-2014, 05:25 PM
Muvovr's Avatar
Quoted: 948 Post(s)
rotorhed1 previously said: View Post
I ran many wires thru a boot on the drivers side. It has a large bundle of wires and the hood release cable running thru it. I stuck a straightened coat hanger thru from the engine side with the new wires and pulled it thru.
I did the exact same thing !!!
Dennx likes this.
2014 Build.
Silver Roof, Pro Comp Lift 3", TRD Wheels, Cooper A/T3 285x70x16, TT Black Out Parts, ARB Touring Rack, Baja Ladder, Bushwacker Fenders, Rigid Upper & Lower Grille w/ SR 6" LED's & D2 LED's, Front Grille Guard, Rigid SR-M Rear LED's, ANZO Headlights & Turn Signals, M-PAC Side Rack, Ellis Precision, TTUE Skid Plate, Rocktek Rear Bumper, PRG Snorkel
..........................____
...............______//__{\___
............./__(0)_//__/_(0)_/
My Post may not be disseminated, without the express written consent of myself or a doppelgänger with a worse attitude then my own.
Muvovr is offline
post #19 of 19 (permalink) Old 07-02-2014, 05:28 PM
Muvovr's Avatar
Quoted: 948 Post(s)
Dennx previously said: View Post
This is how I ran both Power and Ground into the cab for power distribution !!!
Dennx likes this.
2014 Build.
Muvovr is offline
  Toyota FJ Cruiser Forum > Toyota FJ Cruiser Discussion > Stereo / Electronics / Electrical > CB / HAM / Communications
