aFe exhaust owners 3" - Cross member rattle. - Page 2 - Toyota FJ Cruiser Forum
 1Likes
post #11 of 11 (permalink) Old 05-18-2014, 12:32 AM
Quoted: 2 Post(s)
Re: aFe exhaust owners 3" - Cross member rattle.
WaJohnZ previously said: View Post
This may be a problem for you....First the Chrome tip gets "Very hot" you could melt your underside bumper plastic from being so close , you have also taken some of the ability for the muffler to move if anything should contact it. If you place a spacer between the pipe and cross member and slightly turn the tip downwards then tighten the clamps everything should clear.... No beating with a hammer.(remove spacer when all clamps are tight)
Some clamps do not tighten around the pipe before bottoming the threads, you can cut a strip of sheet metal or tin can and shim the inside of the clamp before tightening.
Thanks for the advice, I'll be looking at that in the morning (regarding the heating of the bumper plastic). I knew I was limiting the flexing and rebounding of the rear section of the unit, and will keep an eye on that as well.
DC1381 is offline
