Serpentine Belt Replacement - Toyota FJ Cruiser Forum
 10Likes
post #1 of 12 (permalink) Old 09-02-2017, 07:43 PM Thread Starter
Quoted: 1 Post(s)
Hi. Trying to replace serpentine belt on my 2007 FJ. I'm able to release the tensioner and slip the old belt off the pulleys. But I cannot get the belt around or off the water pump. What am I missing (besides basic mechanical aptitude)? Would appreciate any help that u can offer. Thanks.
Bozeman is offline
post #2 of 12 (permalink) Old 09-02-2017, 07:48 PM
cliffy's Avatar
Quoted: 649 Post(s)
Re: Serpentine Belt Replacement
I had mine off last year. I don't remember there being a trick to it. What is the belt catching on?
Name:	ImageUploadedByAG Free1421509051.824296.jpg
cliffy is offline
post #3 of 12 (permalink) Old 09-02-2017, 07:55 PM
Iconic_'s Avatar
Quoted: 2430 Post(s)
It should just come off! Takes a little effort to get it untangled from everything I think.
Iconic_ is online now
post #4 of 12 (permalink) Old 09-02-2017, 08:02 PM
cliffy's Avatar
Quoted: 649 Post(s)
I think mine kept wanting to catch on pulleys just twist and maneuver it out. It's tight, slide it off the smooth top idler first.
cliffy is offline
post #5 of 12 (permalink) Old 09-03-2017, 11:33 AM Thread Starter
Quoted: 1 Post(s)
cliffy previously said: View Post
Thanks for the reply and diagram. I must not be seeing this right. I release the tensioner and the belt slips off the front of all the pulleys and parts - but it looks like it won't slip off the front (or rear) of the water pump which is connected to the engine block in the rear and the radiator fan in front. What do you think I am doing wrong here? I just had the power steering pump replaced at a shop and when I got home and popped the hood I could see that about a 1/4 inch of the belt had sheared off and bird-nested around the water pump. The shop apparently didn't align the belt correctly in the grooves. Which is why I am trying to replace the belt. Thanks!
Bozeman is offline
post #6 of 12 (permalink) Old 09-03-2017, 11:56 AM
cliffy's Avatar
Quoted: 649 Post(s)
Bozeman previously said: View Post
I just ran out to the garage and took refresher look at mine. I'm supercharged now and that requires shimming of some pulleys so I 'm not looking at a normal setup. I have plenty of room to bring my belt off. If I remember right a normal setup requires twisting the belt to maneuver it between pulleys. If it's hitting the fan blades you can rotate them until the belt slips out. Other than twisting the belt and moving the fan blades there is nothing else keeping it in place. Your just hanging up on something.
cliffy is offline
post #7 of 12 (permalink) Old 09-03-2017, 12:15 PM
cliffy's Avatar
Quoted: 649 Post(s)
Another thing just occurred to me.. If the belt is coming apart a few strands may be tangled around the pump or other pulleys. You'll have to untangle and or cut away the birds nest.
Sanderhawk likes this.
cliffy is offline
post #8 of 12 (permalink) Old 09-03-2017, 12:19 PM
Iconic_'s Avatar
I pulled the belt around the fan. It's doable.
Joabmc likes this.
post #9 of 12 (permalink) Old 09-03-2017, 12:34 PM
cliffy's Avatar
Quoted: 649 Post(s)
He said the belt was falling apart. I'm thinking some of the strands are tangled not allowing the belt to come free.
cliffy is offline
post #10 of 12 (permalink) Old 09-03-2017, 01:29 PM
Sanderhawk's Avatar
Quoted: 912 Post(s)
I second what cliffy said. I had a belt shred and it was a pita to get all the cords and crap off of everything. When I changed my FJ belt it just came right off. Take your time and stop and take a breathe if you get frustrated you`ll get it
cliffy likes this.
Steve.... 07 FJ with almost enough mods.... August 2017 Member of the month
Sanderhawk is online now
