Best Gas Cans and Mounts - Page 6 - Toyota FJ Cruiser Forum
Expedition Specific Equipment If it is unique or integral to Expeditions, it should be discussed here.
 24Likes
post #51 of 58 (permalink) Old 07-20-2018, 10:15 AM
Quoted: 2 Post(s)
Re: Best Gas Cans and Mounts
If you have a ladder on the back of your rig, and don't really use it, I was able to bolt a Smittybuilt can holder onto my Gobi ladder. $36 for the can holder thru Amazon, $13 for the Scepter 5.5 gallon tank at Costco, less than $10 in stainless U-bolts from Home Depot and I'm all set. The holder fits both the Scepter or a 6 gallon Igloo water jug so I put back there what I need for any specific outing.
ID:	1047276   Click image for larger version
ID:	1047278   Click image for larger version
ID:	1047280   Click image for larger version
ID:	1047282   Click image for larger version
CRFjockey, jamesepoop and Prius2FJ like this.
The older I get, the better I was...
2008 FJC TTSE
1996 FJ 80 Landcruiser
1987 4 Runner
1979 Toyota PU
vanimalb is offline
post #52 of 58 (permalink) Old 07-20-2018, 10:57 AM
jamesepoop's Avatar
Quoted: 1114 Post(s)
@vanimalb that loaded up rig is
jamesepoop is offline
post #53 of 58 (permalink) Old 07-30-2019, 06:16 AM
Quoted: 0 Post(s)
That's hot and loaded man!
wmbrn is offline
post #54 of 58 (permalink) Old 07-30-2019, 07:45 AM
jamesepoop's Avatar
I copied @Corey , but made my own base plate for a rotopax. I have the extension but fitted 2 gal for a trip. I'm a bit weak and filling 5 gallons with the Jerry can was fairly tiring. It's about 38lbs and holding it for any amount of time was straining for lifted FJs. Each 2 gallon rotopax is about 18lbs.
ID:	1087800   Click image for larger version
Iconic_ previously said:
LEDLIYFJL: Live Every Day Like Its Your FJ's Last
Mad Maxxine Build - 2007 Fresco Silver Metallic
IG: madxmaxxine
post #55 of 58 (permalink) Old 08-05-2019, 10:03 PM
pjackson4's Avatar
Quoted: 17 Post(s)
To mount Rotopax on a roof cargo cage, what mount was used? I just got the locking mount and 2 gallon gas, but the mount only had a small 6” disc and doesn’t fit cage spaces. I am not great a fabrication, so if anyone has used a specific mount please let me know. Found simple U-bolts at ACE but with a simple nut it seems like it would come loose. Thanks in advanced.
pjackson4 is offline
post #56 of 58 (permalink) Old 08-06-2019, 03:26 AM
jamesepoop's Avatar
@pjackson4 depending on your type of rack, you can bolt your pax mount directly via the rack and drill two holes to install the mount. If you want to use the base plate, you can make something like this or purchase one
ID:	1088706   Click image for larger version
IG: madxmaxxine
post #57 of 58 (permalink) Old 08-06-2019, 12:44 PM
トヨダ Master
CabinCruiser's Avatar
Quoted: 3368 Post(s)
pjackson4 previously said: View Post
jamesepoop previously said: View Post
James' idea is a good one. You can also use Nyloc Nuts to keep the hardware from losening.
jamesepoop likes this.
R.I.P.- Echo
Solitude Allows One to Reflect While Others are Reacting...
It Is Easier To Walk On Hot Coals Then It Is To Walk On Egg Shells...-CC
Member of the month-October 2017
CabinCruiser is offline
post #58 of 58 (permalink) Old 08-06-2019, 07:37 PM
pjackson4's Avatar
Quoted: 17 Post(s)
@jamesepoop @CabinCruiser
Thank you both for your answers. I did also just get a email back from Rotopax and they mentioned a back plate that they sell for $9.99, so I will do that and mock James answer and then get the nyloc nuts to secure it like Cabin said. Again, thanks so much!!!
CabinCruiser likes this.
  Toyota FJ Cruiser Forum > Expeditions > Expedition Specific Equipment
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
bjfutrell
